Command shortcut keys toggle
Affinity Designer has great feature - it enables to toggle between commands.
For example:
pressing v key first time selects move tool,
pressing v key second time returns to previously used command.Or did I missed it in Preferences?
@Blunieb said in Command shortcut keys toggle:
No, this is not present in VS in this form (it has been requested not long ago, and will be available in 1.2).
Currently what is possible is to define custom shortcuts per context. For example, define a specific key in the node editor tool to return to the transform tool.
But this does not replace the on / off mode of course. Will be available soon.
Ok, thank you for explanation
The A key however does that — it alternates between Shape Editing and Object Select/Tranform mode (V).
@b77 said in Command shortcut keys toggle:
Control does the same but alternates between shape editor and last used command.
But I would like to have all commands as toggle
@Blunieb Control (Win) or Command (Mac) indeed does that also but it's temporary toggle — when you release the key you're back to the active tool.
