    Is this selection box intentional?
    5 Posts 2 Posters 4.8k Views 1 Watching
      I was curious if this selection box in the lower left corner of the triangle I made is normal and if so, what does it represent?
      Here is a video showing the steps. When i make a shape and convert to curves, then add a center point and delete the edge nodes at the top, and then select the shape, I get an extra selection box at the bottom left side - is this because it's the starting node?
      0_1664815606871_9e1312c4-061b-4e28-a8e2-bd8f19107052-BLD 2022-10-03 at 12.45.41.png
        @Boldline Yes, this means a single node is selected with the transform tool.
        Selecting the node with the node tool and then changing to the transform tool can result in this type of selection.
          @Boldline If a single node remains selected, it could be a bug. I will try to replicate this.
            @VectorStyler said in Is this selection box intentional?:
            There seems to be an extra node at the end of the process each time, but what's odd is nothing extra seems to remain after deselecting. I tried three times in this video - it seems to matter if you double click to create a center point or not - if you do, the extra node seems to be there temporarily. if you don't add an extra node in the center, it will look correct. I tried with a couple different shapes.
            Further study update:
            With any existing shape if I add a node (double click on path for example) and then delete another and then switch to the transform tool, the extra selection of a node appears. It does remain permanently, but it is a little distracting and confusing lol
              @Boldline I can replicate this issue and it seems to be a bug, it should have the whole shape bounding box. It will be fixed in the next build.
