    Collider Tool Constraint ?
    5 Posts 2 Posters 5.0k Views 2 Watching
    • IgullI Offline
      Igull
      Is there a way to constrain an object's position using the shift key while using the collider tool ?
      For instance, say a small rectangle within a larger rectangle, the collider tool will allow you to collide with one of the edges - let's say the RHS, but when attempting to move the small rectangle up to collide with top of the large rectangle, you can't constrain the small rectangle to hold it's horizontal position that you just created.
      TIA
      Neil
        VectorStyler @Igull
        @Igull No such constraint.
        But if you want to collide a shape with two other shapes / directions then use collision snapping and the regular move tool.
        Collide tool will also rotate the shape to match the normal, so in this case it might not be suitable.
        Collision snapping mode will align the shape to two touching shapes.
        IgullI 1 Reply Last reply Reply Quote 0
        • IgullI Offline
          Igull @VectorStyler
          @VectorStyler said in Collider Tool Constraint ?:
          I've just created a fresh file - two rectangles, one within the other - using the move tool and with collision snapping , allow snapping and snap to objects enabled, I can snap the smaller rectangle in say the Y direction, but when attempting to snap to a vertex in the X direction, it won't snap to the vertex of the larger rectangle, it seems to want to track the X axis along the original snapped position (you can see the red indicator line) without taking into account the direction it's moving to pick up the next snap.
          I know I could easily just use snap to points, but that wasn't the usage here 🙂
          Attached a vid for clarity ...
          Collider constraint issue
          TIA
          Neil
            VectorStyler @Igull
            @Igull There is a bug here, will be fixed ASAP.
            • IgullI Offline
              Igull @VectorStyler
              Thanks
              Neil
