Deleting values in layers transparency
If you select the entire transparency value in a layer and press delete, it is removed, but VS inserts the value 0.0% in the field.
If you then enter 100, it is put in front and you have 1000%
The logic must be, you remove the selection in the field completely to insert something else of your choice, not to set the value to 0,0.
So the appropriate behaviour must be that after deleting the selection the cursor is in a completely empty field.
And by the way, I'm still of the opinion that decimals in layers transparency should only appear if you (rather unusually) entered a decimal yourself. Otherwise just the whole integer value as 50% displayed please.
@Ingolf The number fields in the Color panel work the same and I can't say that zero you get when you delete the value is useful.
@Ingolf I added this to the backlog.
@VectorStyler said in Deleting values in layers transparency:
Consider other input fields as well... I think I experienced it elsewhere is VS.
@Ingolf This issue should be fixed in build 1.1.062
Indeed it does - but the transparency panel itself does nothing now? No effect of any value using sliders or keyboard? macOS
@Ingolf said in Deleting values in layers transparency:
Regression, will be fixed ASAP.
