    Questions about Stroke scaling in VS
    4 Posts 2 Posters 4.5k Views 2 Watching
      Subpath
      I dealt once again with stroke scaling in VS, due to the thread from Boldline about it.
      Stroke scaling worked with my attempts only if "Scale Image Filters"
      and "Transformed Stroke" are selected
      Is that the way it is supposed to work, or is there another way ?
      -- (I thought for example only selecting "Transformed Stroke" would be enough)
      Especially unclear for me is the menu item "Scale Image Filters".
      in connection with a Stroke scaling.
      -- what is the reason for this ?
      -- what are the advantages ?
      Would be nice if someone could help me out with these questions
        VectorStyler @Subpath
        @Subpath stroke transformation and image effect parameter scaling should work independently in VS, that is why there are two options.
        So "Scale Image Filters" should have no impact on the stroke scaling (unless there is a bug).
        Transformed Stroke set in the Layer/Object Options view applies to all objects inside the layer or group.
          Subpath @VectorStyler
          @VectorStyler said in Questions about Stroke scaling in VS:
          then it seems i stumble across a bug
          will report it later with a video in "Bug Section"
          thanks for the Info
            Subpath
            I am yet a bit unshure if this is really a bug, so i post
            that Video here.
            Forgot to mention in my previous Post here
            that in this case I did the stroke scaling via
            the menu in the Appearance Panel
            If I do the stroke scaling this way then it works only
            with "Scale Image Filters" set
            Here the video
