Option to show existing location of path in ghost form as you move a node
It would be helpful to me to have a way to move an existing node and not lose the exact angle I was working from in the process. In this example, I want to move the node down to overlap the path so I can trim it, but when I move the node, I lose track of the exact angle I had.
I could add a guideline, but it would be nice if there was a way the original could be a ghost and even have the current node snap to its former self temporarily.
EDIT: I realized I can add a node very close to where the node I want to move is located and protect the angle some that way. I know we've mentioned in the past adding the ability to give a visual indication when an edited node is in line with the rest of the path - could that be a solution for this?
@Boldline Would this issue be solved if the Direct Preview Mode is disabled?
Also the direct preview option can be disabled/enabled selectively for individual editors in Preferences -> Direct Preview.
This is how it functions in Illustrator - when you move a node, the path becomes highlighted and you can see where it was before. Ignore the first part of the video - I grabbed it with the transform tool by mistake instead of the node editing tool
Here is the video
@Boldline said in Option to show existing location of path in ghost form as you move a node:
That is how it will work in VS if the Direct Preview Mode is disabled.
@VectorStyler ok - got it. I see what you mean on that now - thank you
@VectorStyler In this topic, I mentioned a problem regarding the visibility of the selection.
After disabling Direct Preview, an analogic problem appears.
https://recordit.co/oL9wNFj1TzAs for sliding along an angle. Wouldn't it be possible to integrate that under the Shift key along with the vertical and horizontal snapping?
@VectorStyler on a related note to @encart 's video, the first time he tries to move that node, he grabs it and it does not respond at all - (the second time he is able to move it -albeit it went wonky on him from that point forward)
Focusing for a minute on the first issue - I see this happen often, especially using the stylus. Going back to an existing node, I often need to click and drag more than once for it to get recognized.
@encart said in Option to show existing location of path in ghost form as you move a node:
After disabling Direct Preview, an analogic problem appears https://recordit.co/oL9wNFj1Tz
I could not replicate this (with the default settings).
Yes, this should work when holding Shift, if the angle snapping is not too small.
@VectorStyler said in Option to show existing location of path in ghost form as you move a node:
Does not work in my case. https://recordit.co/sP7fN2a4mI.
I was referring to the movement of control points around curves. For lines this is not working.
I was thinking about something simillar to mechanic implemented in Designer. https://recordit.co/b9YMvXGDUR
I was thinking about something simillar to mechanic implemented in Designer. https://recordit.co/b9YMvXGDURMaybe as a new feature.
@encart yes! that would be an awesome addition! That is a better idea than I was thinking of and I would use it often
like that idea too
