Issues with the Pen tool & Intuos4 tablet
Hi,
No issues with the mouse but I can't use the pen tool modifiers keys (Alt or Shift ; express keys of the Intuos or normal keyboard ) with the digital pen of my tablet.
Thanks,
Patrick[edit: last drivers installed for the Intuos4 (6.341-1)]
Edit2/ correction: what it is not working is the previsualization of the stroke as soon as alt or ctrl key is pressed.
@PatrickM Added this to the backlog
@vectoradmin thanks but still unusable for me & my tablet.
@PatrickM This can be replicated on Windows, and the same issue occurs when using the AltGr (right alt) key.
The only workaround for now is to use the left alt key on the Windows keyboard. I will try to fix this as soon as possible.It is not an issue with the tablet type or driver, it is a problem in the VS port on Windows
@vectoradmin Thank you
I am well aware that this is an old tablet (for which even Wacom has stopped upgrading its drivers) and that there are so many different manufacturers and models that it must not be easy to manage for VS... but it still works very well and I avoid consumerism for the sake of our environment.[edit : I just read that it is not related to the tablet model]
@vectoradmin said in Issues with the Pen tool & Intuos4 tablet:
It does not work for me (left or right, tablet or keyboard).
Edit: issues also occur with the "Shape editor" tool.
@VectorStyler said in Issues with the Pen tool & Intuos4 tablet:
@VectorStyler I hope a fix will come soon
@PatrickM I will try to have something on this in the next build.
Nice, thanks !
1 issue I just encounter with Intuos tablet in moving by selecting multiple objects with Shift key (not affect if selection is made by dragging). When tried to move two objects by selecting with shift+ key the other object disselect.
@PatrickM The new build (1.1.040) contains Windows compatibility improvements, including better handling of tablets.
Let me know how this works for you.
@VectorStyler much better now
I'll test further. Thanks.
