    Default built-in 3D Stars?
    23 Posts 6 Posters 37.7k Views 5 Watching
      I needed a 3d star today in my work and it prompted me think about adding that into VS as an option for quick creation in the star panel. both as a regular star and a "bloated" star.
      I know alternatively, a user could make or import a 3d star and save it as a custom preset or style. 3d stars seem to be common enough to consider adding an option for it on a default level in VS
      0_1649432803851_36dcf0a7-5f6f-41ae-a29a-2eb8462457dc-BLD 2022-04-08 at 11.45.37.png
      VectorStylerV S 2 Replies Last reply Reply Quote 1
        @Boldline I added it to the ideas backlog for the future. I think technically it would involve to options only (enable, and the width of the thin side), so would not make things too difficult.
        • S Online
          Subpath @Boldline
          @Boldline
          I have developed a workaround for such cases a while ago.
          You need a circle clipped in a star.
          First use a 6-pointed star to get the circle in the middle of the star
          and then change it to a 5-pointed star, or any you like.
          Here is the video
          Star Workaround
          BoldlineB 1 Reply Last reply Reply Quote 3
            Boldline @Subpath
            @Subpath very cool! thanks for sharing. I'll still advocate for it being built in to VS in some capacity , but it's really cool what you were able to do to make one
            • S Online
              Subpath @Boldline
              @Boldline , your welcome
              By the way, I'm also an advocate of something like this.
              I have also already pleaded for a section for polygons.
              Sections for Polygons
                Boldline @Subpath
                @Subpath yes there could be some other ways to incorporate that 3D feel into other shapes like the polygons.
                • encartE Offline
                  encart
                  The first idea that came to my mind to create such a star quickly and accurately looks like this. The first one shows an example from AI, because only there I managed to do it as planned.
                  https://recordit.co/OepFHuqCQL
                  Unfortunately, in VS, I was unable to successfully apply the shape tool.
                  https://recordit.co/SKiNQcv8HQ
                  For me in this case it would be natural:
                  • Draw a star
                  • Draw cutting lines
                  • Select everything and cut into pieces with a boolean operation
                  But as I mentioned in another topic, the functions that do this expand the paths and thus there is space in between. Additionally, in the case of concave angles, the lines should have caps. Otherwise there is a problem like here.
                  I wanted to use a knife for this, but snapping is not working for that tool. Hence, there is a lack of accuracy.
                  If there is any proven method for precise cutting I will be grateful. Even on this example.
                  VectorStylerV S 3 Replies Last reply Reply Quote 3
                    VectorStyler @encart
                    @encart Added the shape builder issues to the backlog as a bug.
                    Victor VectorV 1 Reply Last reply Reply Quote 2
                    • S Online
                      Subpath @encart
                      @encart
                      As I watched your video, I remembered a way I found
                      out a while ago while experimenting with VS.
                      Works similar to yours. But I create the lines
                      using the "Square Star" tool. When I do it
                      this way, the "Shape Builder" Tool also works.
                      ( maybe the lines have to overlap ? )
                      Here a Video this way
                      Section Lines with Square Star Tool
                        @encart said in Default built-in 3D Stars?:
                        If there is a file which could be used to replicate this issue, please send it to me by email. Thanks!
                        • encartE Offline
                          encart @VectorStyler
                          @vectoradmin I sent you the file. Recreated but same result as before.
                          https://recordit.co/4GDGsdxMus
                          @Subpath Tried with overlapping lines, but same result. Works better when lines are expanded and merged into one shape. Imo these problems may be caused by center point.
                          https://recordit.co/IUWXtbxh7U
                          Edit:
                          Another way to make it: https://recordit.co/z3VzXOVjkn
                          • S Online
                            Subpath
                            If i convert the modified "Square Shape" to curve,
                            the result will be one Shape. Maybe thats why it works.
                            Video1
                            It also works when I drag Line through the Star
                            and copy and rotate the Line
                            Video2
                              VectorStyler @Subpath
                              @Subpath The last build contains some improvements to the shape builder tool working with open paths (and lines).
                              Using similar steps as @Subpath , but with Snap to Point and the Shape Builder tool: https://recordit.co/WjViOwpZid
                              • S Online
                                Subpath @VectorStyler
                                cool, great 👍
                                that offers possibilties for other Projects too 🙂
                                • encartE Offline
                                  encart
                                  Still have problems on Win10.
                                  https://recordit.co/FDXtnHutP3
                                    @encart Send me the file, where the shape builder is not working.
                                    • S Online
                                      Subpath
                                      no problem so far, is working
                                      also under Win 10
                                      But at the very first point there is
                                      no snap and no snap indicator
                                      ( little red circle )
                                      Edited:
                                      The peak of the ShapeBuilder results and the resulting oversize
                                      was, as @Jayanta-Das wrote, because of the stroke applied to
                                      the outside of the shape
                                      Video: see here
                                      • J Offline
                                        Jayanta Das @Subpath
                                        @Subpath Confirm no issue in Windows 11.
                                        I think the oversized is due to the stroke applied to the outside of the shape.
                                        Mac Mini M4 Pro | 24Gb
                                        WIndows 11 | Intel i5 11Gen
                                        Wacom Intuos Pro
                                        • S Online
                                          Subpath @Jayanta Das
                                          @Jayanta-Das
                                          ...I think the oversized is due to the stroke applied to the outside of the shape...
                                          yes, your right
                                          was probably in sleep mode 😴
                                          Did not realize it
                                          But the very first point did not snap
                                          • J Offline
                                            @Subpath
                                            Yes, didnot snap here also.
                                            Wacom Intuos Pro
