Exit text editing mode
  • We've already written about quitting the text editor before.
    I have not tested it, but I can see that in Photoshop it is done with the Ctrl + Enter shortcut. What if it had worked in a similar way here? This combination would result in quitting the editor, selecting the text and activating the Transform Tool.
    Is the mentioned combination already reserved?
    The inconvenience it may cause?
  • @encart said in Exit text editing mode:
    Just sharing some inspiration, personally I do not jump in and out from text boxes, so I will stay in the background a bit:
    Illustrator text box
    Photoshop
    I don't think Adobe succeeded in creating total shortcut consistency across their programs.
    But personally my first instinctive move would be to hit ESC.
  • @Ingolf As for me, ESC is fine as well.
    I am more concerned with continuing to edit smoothly. Currently, Single clicking ESC exits the text field and allows you to create a new one, but still blocks tools shortcuts. So, maybe a double click could exit the Text Tool completely and switch to the Transform Tool and select the last created item?
  • @encart Esc makes most sense, and is also used in CorelDraw, IIRC.
    Some of it sounds like a Windows port issue. After pressing ESC on macOS I can easily press V, A and activate other tools.
    "maybe a double click " You mean hitting ESC twice?
    Whatever suits the users of this (and perhaps even mimics commonly used and popular shortcuts from Corel/Adobe) as long as pressing ESC one time doesn't deactivate the text tool in the toolbar.
    Small related observations for @vectoradmin
    A
    • Transform tool active
    • Press T
    • Text tool is active
    • Create text frame
    • Edit text
    • Observation: Pointer switches to text tool
    • Hit ESC
    • No tool is visually active in the toolbar
    • Text tool is active if you look at the pointer
    = Text tool visually active in toolbar and activated as well code-wise, I can create more text frames
    B
    • Select other objects with transform tool
    • Select a text frame
    • Transform tool is visually active in toolbar
    • Double click text
    • Observation: Pointer switches to text tool (correct)
    • Press ESC
    So in short the toolbar sometimes doesn't indicate what tool is actually active. 🙂
  • @Ingolf said in Exit text editing mode:
    So in my case something is definitely not working as it should. After pressing Esc, I cannot use any letter based shortcuts. I have to click on the tool in the toolbox.
    @encart Yes, it seems that on Window using Esc does not completely "exit" text editing.
  • @vectoradmin said in Exit text editing mode:
    Indeed, verified on my Windows 10 machine too.
