Can SHIFT + Arrow Key movement increment be adjusted?
Hello,
I understand that the arrow key movement increment of a selected object can be adjusted under Preferences > Adjustments > Move by Keyboard, as well as from the Context Panel.Is it possible to change the movement increment when the SHIFT is held down?
If it is possible to change, is there an option to make it a constant value?It seems to be fixed at 10 times the value of the "Move by Keyboard" setting.
@Victor-Vector There is no option to changed that now. Should that be an option that sets the multiplier?
@vectoradmin Thank you for letting me know.
My urge is to say yes, but I am torn because I would rather not burden you with insignificant requests.
If it was easy to expose the multiplier and you had the bandwidth to do it, It would logically fit in the above mentioned preferences section
@Victor-Vector I add this to the backlog, it is not a hard thing to do.
