Could path brush tool , eraser, node remover tool, corner size painter, knife, etc have autonomous settings?
  • Could all applicable tools nested in the third option down from the top of the vertical toolbar be given autonomous setting controls?
    I noticed for example, if I use the path brush and I set the stabilize to "rope", if I later switch over to the eraser tool, it also has stabilize set to 'rope". If I switch it back to "none" and then alter go back to the path brush tool , node remover tool, corner size painter, knife, etc, it applies the same settings to those tools.
    This gets distracting because I often have one way of using one of these tools and another way of using another. If I switch it for one tool I have to go back and keep switching them around for the rest
    @Boldline I add this to the backlog.
    @Boldline Try using the Shared Brush Options in the Preferences -> Adjustments section.
