    Need some advice on pen pressure
    20 Posts 3 Posters 15.6k Views 3 Watching
    • J Do not disturb
      Jayanta Das
      I am using Wacom intuos pro tablet. I can't figure out how to enable pen pressure on brush and pensil? Done everything on pressure setting, getting nothing.
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
        VectorStyler @Jayanta Das
        @Jayanta-Das When the Pencil (or Brush) tool is active, the context panel should contain a Pressure drop down.
        By default, this contains "None". Select the "Pressure" mode here.
        • J Do not disturb
          Jayanta Das @VectorStyler
          @vectoradmin I did that. But the nothing changed. It is same as selecting Pressure none.
          Wacom Intuos Pro
            @Jayanta-Das What tool is selected in the toolbox?
            • J Do not disturb
              @vectoradmin I tried with both pencil and brush
              Wacom Intuos Pro
                @Jayanta-Das I just tried the Pencil on Windows 10 with a Wacom Intuos touch tablet, and it is working.
                What kind of tablet you tried with?
                I have a collection of Windows 11 issues, I add this to the list.
                • J Do not disturb
                  @vectoradmin It is Wacom Intuos small pro 2019 model.
                  And here is the recording how I have tried
                  https://recordit.co/S9zGfp3MvV
                  Wacom Intuos Pro
                    @Jayanta-Das One more question: what is the width shown in Stroke (or Brush Style) panels, after painting?
                    • J Do not disturb
                      @vectoradmin By default is is 32pt.
                      Wacom Intuos Pro
                        @Jayanta-Das For the Pencil tools at least, it looks like the stroke width was thin when the painting started.
                        Try setting the 32 pt first and then paint with the Pencil tool.
                        • J Do not disturb
                          @vectoradmin I doesn't do anything, I tried setting it to 32pt and paint with pencil.
                          Wacom Intuos Pro
                            @Jayanta-Das Is the paint at least a solid 32pt width line?
                            • J Do not disturb
                              @vectoradmin Yes. it paint in 32pt if selected.
                              Wacom Intuos Pro
                                @Jayanta-Das Then it looks like it is not getting the pressure info from the system.
                                This is most likely a Windows 11 compatibility issue (have a few of these).
                                • J Do not disturb
                                  @vectoradmin I don't know but I might be wrong, I think pen pressure was working in the previous build.
                                  Wacom Intuos Pro
                                    @Jayanta-Das This can be checked: the previous build can be downloaded from https://www.vectorstyler.com/releaselog/ If you scroll down a bit, it was 1.1.008
                                    The link to the previous windows version is: https://www.vectorstyler.com/buildv1_1_008/vectorstyler.msi
                                    You need to manually uninstall the current version.
                                    • J Do not disturb
                                      @vectoradmin Ok. I will install previous build, check and let you know by tomorrow.
                                      Wacom Intuos Pro
                                      • encartE Offline
                                        encart
                                        @Jayanta-Das You're not the only one. In my case, pressure recognition also doesn't work. However, I do not need it. I have a Huion Q620m tablet and this problem has been around for a long time, not the current build. The pressure is detected during testing in the driver window as well as in applications such as Affinity photo. However, neither of the suggestions work either. The latest driver is installed.
                                        • J Do not disturb
                                          Jayanta Das
                                          @vectoradmin @encart I was wrong. Pen pressure doesn't work in the previous build also.
                                          Wacom Intuos Pro
                                            @Jayanta-Das Then this is still an open bug, it has been reported before.
