Cannot re-use my license
Hi there!
My hard drive crashed and I had to reinstall Vectorstyler on a new one. When I try to register, I get a message saying that the license was already used. Any idea?
Thanks
@Olich You need to add a user name and email also. Do you remember it?
If not, please send me an email to csraba at vectorstyler.com and I will try to reset in the license server.
@Olich Send you an email with some info. Let me know if that helps.
Great! It works now. Thanks a lot!
This issue could occur due to some temporary issues with the verification services. After you click on the option to send a verification code to your phone, you will be presented with a box to enter the code and an option to resend the code below the box. I would suggest you try resending the code. If you had set up other options for security verification, click Other verification options, and then try again by selecting a different option. Also, make sure that your phone numbers are correct in your user account settings. You can also try using DATA RECOVERY programs if no solution works.
