Fill and outline in toolbox?
Another query. Can I enable fill and outline in toolbox? thank you. -
@Jayanta-Das No such feature in the VS toolbox.
Use the color panel (or palette panel) to select colors. -
Thank you. It would be nice to have this feature.
The bottom of the toolbar is how most vector programs placed their color fit and stroke. It was hard for me to get used to at first, and I may have questioned at the time why it was not in the toolbar like the others. Now I'm comfortable with it in the color panel and that is where I look first instead of at the bottom of the toolbar.
Is it redundant to add it to the toolbar? I'm just asking questions
I am now not sure about this one. I prefer the color selector in the toolbar in Photoshop because I often work in full screen with only the toolbar showing and I need the color picker to check if white or black is selected for masks. I prefer as much screen estate available as possible - for viewing the image as a whole.
In both VS and Affinity I got used to having the color panel without spectrum positioned above the layer panel - docked on the right side. I need both and always I need the HSL etc. sliders for adjusting colors. The "loss" of screen estate is fine. I am zoomed in most of the time.
So it depends on use cases I guess.
Adobe has two versions of the color picker in the toolbar. A big and a small one - for single row mode and bigger for more rows.
@Jayanta-Das I add this to the backlog as a feature request.
@vectoradmin Thank you. I didn't expect that.
@Ingolf said in Fill and outline in toolbox?:
In both VS and Affinity I got used to having the color panel without spectrum positioned above the layer panelFor anyone who uses the Affinity products and didn't catch this, the colors do show up in the tools if it is configured to be more than one icon wide (it is one by default).
@fde101 Yep. Probably because when the toolbox is one row only, it gets so tall that the Fill and Stroke buttons would not be visible on 14" and 13" laptop screens.
Adobe solved this "problem" with a small color selector - this screenshot is from a 14" laptop with plenty of space for the single line toolbar in at least Photoshop.
Affinity Designer has so embarrasing few features that Serif put shapes in the toolbar as fillers, so they could easily find room for a small color selector. If they wanted to.
Affinity Designer Screenshot from Windows, 14" screen. With all the shapes in the toolbar still tons of space:
But just to clarify - I would only want this feature myslef in an image editor personally so I am just illustrating.
]I'm not using AD at all, so when seeing the screenshot posted by @Jayanta-Das I assumed that putting the two rows of icons on top of each other will make the toolbox taller than a 14" screen.
But it looks like AD automatically switches to a compact version of the toolbox when switched to One Column mode?
Anyway, I'm afraid this would happen on 14" and 13" screens with VectorStyler's toolbox when switched to One Column mode.
@b77 said in Fill and outline in toolbox?:
Serif didn't develope enough features for a non-compact toolbox in Affinity Designer, so no. These are the defaults in one and two column modes.
I navigate so much faster to the icons with a single column toolbox so I never used their two-column toolbar and discovered that I didn't miss the color chooser from the toolbox at all. I always need quick access to the sliders.
@Ingolf Don’t miss it either. Maybe as an option it won’t hurt.
13" is too small for a gfx software default config - that requires compromises. But yes even on 14" we would probably start to run out of screen estate.
There are options though - first of all VS is mighty configurable - the UI can be scaled and the toolbox icons can be scaled to three pre-defined sizes from Panels -> Toolbox style. More options are possible in the future should @vectoradmin feel for that. The architechture seems to be there.
From Panels -> Toolbox style you can also select a compact toolbox that I think could be watered down even more.
The default toolbar is impressive though - and well thought out. But also packed. I think adding a color selector would add visual clutter no matter how useful it might be.
I'm working on a large monitor and I set my toolbar icons to be smaller than default, just based on my preferences. Even if the toolbar had more icons, it would not feel overpacked to me.
I understand the need to be considerate of smaller screen sizes; if @vectoradmin were to add the fill/stroke chooser to the vertical as an option, I could see that being a beneficial solution.
