    Gradients copied and exported as images in PDF and SVG
    4 Posts 2 Posters 6.7k Views 2 Watching
    • IngolfI Offline
      Ingolf
      I (suddenly?) have the issue that copying a simple two color two stop gradient to Affinity as PDF or SVG is carried over like an image.
      To my surprise also exporting the same basic shape with a basic gradient is exported to PDF and SVG as images as well? If I open them in VS after exporting them from VS I just see images. No gradients.
      🍏 macOS Sequoia Apple Silicon
        VectorStyler @Ingolf
        @Ingolf Can you send me a gradient example that exports as image.
        Typically (if linear or concentric), the gradient color transition and color mode may impact whether it is exported as an image or as a gradient.
        • IngolfI Offline
          Ingolf @VectorStyler
          @vectoradmin said in Gradients copied and exported as images in PDF and SVG:
          Can't reproduce now that I switched to RGB from CMYK... so that was the root cause, CMYK?
            @Ingolf said in Gradients copied and exported as images in PDF and SVG:
            Could be. At least in the case of SVG, the color transition made in CMYK mode cannot be simulated in RGB mode.
