    Can I add custom keyboard shortcuts to Boolean operations?
    7 Posts 3 Posters 9.1k Views 2 Watching
      What would be the easiest way to add custom keyboard shortcuts to some of the boolean operations?
      encartE b77B 2 Replies Last reply Reply Quote 0
      • encartE Offline
        encart @Boldline
        @Boldline
        View > Customize > Keyboard Shortcuts
        Then, In 'Actions' section go to Object> Combine. Select an operation and add it to shortcuts.
        • b77B Offline
          b77 @Boldline
          @Boldline Here's how:
          • choose 'Keyboard Shortcuts' from the VectorStyler menu;
          • choose 'Multiple Selected Objects' from the Context menu;
          • expand the 'Object' folder in the column on the right, then its 'Combine' subfolder;
          • choose let's say 'Union';
          • click the 'Add Shortcut' button;
          • click the right side of the new entry, under the 'Shortcut' column;
          • press the key combination you want to assign;
          • click 'OK'.
          Quick video here: https://recordit.co/GoCw7pAMx4
          b77B 1 Reply Last reply Reply Quote 3
          • b77B Offline
            b77 @b77
            @encart shows where to find keyboard shortcuts customization on Windows and I show where to find it on the Mac. πŸ™‚
            • encartE Offline
              encart @b77
              @b77 Oh I forgot @Boldline is on a Mac and there can be differences. Apart from that, your way is better because it relates directly to the context.
                Boldline @encart
                @encart @b77 Thank you to both of you! I appreciate the help. I was having trouble tracking them down for some reason
                • b77B Offline
                  b77 @Boldline
                  @Boldline It looks like if you add a shortcut with Option, you’ll get a composite object instead, so don’t use that if you want normal combine operation.
