[Object Export Panel] How to save custom formats preset for use in other documents.
I have a problem with it. Maybe I don't understand something.
I don't need to save collection with objects. Just want to keep files format with settings for future use.
@encart After choosing one of the existing presets (say, PDF) you can change the export resolution from 120 to 300 dpi, go under the Text tab and check 'Vector Text' and do any other changes you consider.
Then you can save it as a preset by clicking the 'Save as Preset' option from the 'Style' dropdown at the top (let's say, 'PDF for print 300dpi').
Afterwards the preset will be available in the same 'Style' menu at the top.
