    Can strokes with width adjustments be blended?
    15 Posts 4 Posters 11.8k Views 3 Watching
      Boldline @Subpath
      @Subpath you tried with the file I included?
        Subpath @Boldline
        no, made a similar Stroke like yours.
        but will also try your file now, just a moment 🙂
          Boldline @Subpath
          @Subpath ok thanks - the reason I ask is because with those strokes, I had used the path width tool and that was where it seemed to give me issues trying to blend it properly afterward
            Subpath @Boldline
            first observation
            the two strokes seems some how connected
            if i hover over the left one both get selected
            • no regluar blend visible
            as i copy and paste both the connection seems gone
            also no regular blend, and if i expand the blend
            i get only lines
            also no regular blend i copy the your strokes to new file
            Here the video
            attemp with your file
            in the video the left one is already blended
            and expanded
              Boldline @Subpath
              @Subpath said in Can strokes with width adjustments be blended?:
              This is not happening with the strokes here - they are not grouped or connected
                Subpath @Boldline
                yes there is no group an i also found no combine
                here is the video where i restarted VS
                and only load your file, seems sometimes
                connected and other not
                just your file
                  Boldline @Subpath
                  @Subpath thanks for checking that - it may just be an odd obscure situation that @vectoradmin can figure out why it is occurring that way..
                    b77
                    @Subpath They are connected because they form a blend object already. But since they are so close to each other, the first object is more difficult to select separately (hover the cursor on its left and click).
                      @Boldline Indeed this seems to be a bug — if you get rid of the brush contour of both red lines the interpolation works.
                        Subpath @b77
                        ah, interesting good to know
                        but curious
                          @Boldline I think the issue is that these two shapes contain brushes, and it seems that the brush content is not blended.
