    Opacity (0-9 keys)
    16 Posts 4 Posters 12.7k Views 3 Watching
      @vectoradmin Could we get the small data popup confirming the new opacity percentage when we swap the opacity using the number keys? So if I have an object selected and I tap the "2" key, we see the "20%" appear overtop the shape and then fade out?
      It should refresh with every key stroke edit.
      This will provide quick visual confirmation of what percentage is now current with the selected object(s) Thanks!
        @Boldline Yes, this is doable.
          Typically in other programs, clicking on the Zero key will return the opacity of any shape back to 100%. I noticed that does not work for me in VS with the new opacity key settings. Others can correct me if I'm wrong, but this has been industry standard.
          I did notice that if I press the same key enough times, it eventually goes back to 100% opacity (what is it going to in the middle steps? I understand the first tap of a key like 4 makes it 40%, if i then tap a 6, it becomes 46%, if I tap 4 again and then again... it does other things before getting back to 100%
          J 1 Reply Last reply Reply Quote 2
          • J Offline
            Jayanta Das @Boldline
            @Boldline Still seems there is some issues. single tap double tap same number working. but is tap like two different number then it gives another value.
            e.g. 34 gives 44, 35 gives 55, 21 gives 11 values
            Mac Mini M4 Pro | 24Gb
            WIndows 11 | Intel i5 11Gen
            Wacom Intuos Pro
              VectorStyler @Jayanta Das
              @Jayanta-Das Tried this on Windows, but could not replicate.
              • J Offline
                Jayanta Das @VectorStyler
                @vectoradmin Ok just to test I forgot to place any object inside the layer and tap the number key that gives that values. Now again after adding a shape and tried it works.
                Wacom Intuos Pro
                • J Offline
                  Jayanta Das @Jayanta Das
                  @Jayanta-Das @vectoradmin In AD when layer is selected and tap the number key opacity is apply to the layer and if any object is selected then it applied to the object only.
                  Wacom Intuos Pro
                    @Jayanta-Das said in Opacity (0-9 keys):
                    That should also be the case in VS, except the Layer must be selected with the small circle at the end of the layer name row (selections in the Layers panel are not the same as on the canvas).
                    • J Offline
                      @vectoradmin I did as you said. Recording
                      You can see in the recording when I select layer and tap on number key nothing happen.
                      Wacom Intuos Pro
                        @Jayanta-Das is right.
                        • If I select a layer (single click in layers panel!), no response from numeric keys
                        • If I then select the first object in the layer in the layers panel, no response from numeric keys
                        • If I then select the same object on the canvas, numeric keypresses activate the opacity setting code
                        • If I then select another object in the layer in the layer panel, no response from numeric keys
                        Etc. 🙂
                        VectorStylerV J 2 Replies Last reply Reply Quote 2
                          VectorStyler @Ingolf
                          @Ingolf Now I got it! It is because the Layers panel has the key input and consumes it.
                          I will try to fix it. Meanwhile, clicking in a filled area of a selected object (or layer) should set the key input to the editor.
                            @vectoradmin Happy to help 🙂
                            • J Offline
                              Jayanta Das @Ingolf
                              @Ingolf Thanks for explaining nicely.
                              Wacom Intuos Pro
                                Ingolf @Jayanta Das
                                @Jayanta-Das You're welcome 🙂
