Separate Path missing from keyboard shortcut panel?
I was trying to find the "separate path" in the keyboard shortcut panel to give it a shortcut but I was not able to find it either by manual search or by using the search box at the bottom.
is it under a different name? Did I miss it somehow?
@Boldline Will fix this for the next build.
@vectoradmin excellent, thank you!
When I was using Illustrator, they had it set up where the "ungroup" would do essentially what separate path" does in VS. In the work I do, there's a lot of taking things apart, so I used the "ungroup" shortcut in Illustrator all the time over and over - in VS, I understand the ungroup has different features than the separate path and I'm fine with that, as long as I can get a shortcut for "separate path" so I can do it quickly and easily. -
