    Understanding pen tool
    50 Posts 8 Posters 140.2k Views 7 Watching
      VectorStyler @Devil Dinosaur
      @Devil-Dinosaur If you refer to the image with the A, B and C labels, then that is visible.
        b77 @VectorStyler
        @vectoradmin Strange… not visible in Brave, visible in Safari and Firefox…
          encart
          @vectoradmin Photos are not visible on Chrome
          • Devil DinosaurD Offline
            Devil Dinosaur
            "L" and "Y" and the C conversion work fine 👍
            I also use Firefox and Safari, that's why I assumed that everyone could see the picture.🤔
            Fred.
              Another option is to use the option/alt key on the last point before you let go to complete the loop.
              Then you only need to adjust the line a little after
                VectorStyler @Jayanta Das
                @Jayanta-Das In AD when you draw with the pen tool, after the second node how to you retract the control handle? (when the node changes from circle to square indicator).
                • J Offline
                  Jayanta Das @VectorStyler
                  @vectoradmin It is same as VS, just click on the node.
                  Mac Mini M4 Pro | 24Gb
                  WIndows 11 | Intel i5 11Gen
                  Wacom Intuos Pro
                  • J Offline
                    Jayanta Das @Jayanta Das
                    @Jayanta-Das Controls of handes while using pen in AD: Record
                    • Handles of Second node are controlled by Ctrl key
                    • Handle of Third node is controlled by Ctrl+Alt keys
                    Wacom Intuos Pro
                    • Victor VectorV Offline
                      Victor Vector
                      @Jayanta-Das, @vectoradmin
                      I have to admit, using ALT to "break the handles" to convert a newly drawn node to a cusp node is something I really miss coming from AI and AD. It's one of those great features that is so handy to have integrated in the pen tool and greatly speeds up one's workflow.
                      BoldlineB VectorStylerV J 3 Replies Last reply Reply Quote 3
                        Boldline @Victor Vector
                        @Victor-Vector @Jayanta-Das I have to admit in all my years using Illustrator I never used the option key for that - I was playing around with it some still trying to figure out how to best use it for cusp nodes.
                        Typically in Illustrator, I would click again on the node I wanted cusp and then continue onward.
                        For lack of a better explanation, I get the sense @vectoradmin has a purist mindset in terms of not limiting tools and options with a "quick and dirty" option that may be quick, but limits options. I see this with the node tools where I once advocated for the same quick options (Shift-C was added to VS like it is in Illustrator for example and that was enough for me) I notice it also with things like using the eyedropper to copy attributes
                        I think the answer is to have options for both quick and dirty and full options
                          VectorStyler @Victor Vector
                          @Victor-Vector said in Understanding pen tool:
                          When not closing paths, the ALT key should work in the pen tool to create cusp nodes, in the current version.
                          The closing path bug will be fixed in the next build.
                          • J Offline
                            Jayanta Das @Victor Vector
                            ALT key works in pen tool as in AD or AI.
                            Wacom Intuos Pro
                            Devil DinosaurD 1 Reply Last reply Reply Quote 0
                              Devil Dinosaur @Jayanta Das
                              Only while you draw. If you want to quickly modify some single handle after closing the shape, you need to use the "L".
                              That's what I found a little bit complicated compared to AI or AD, but it works.
                              Fred.
                              J 1 Reply Last reply Reply Quote 2
                              • J Offline
                                Jayanta Das @Devil Dinosaur
                                You are right. After the path closed, CTRL + ALT is usefull in controlling handles and modifying smooth node to cusp node.
                                Wacom Intuos Pro
                                  Victor Vector
                                  Maybe I am missing something, or maybe I have an unusual setting, but I cannot get ALT or CTRL to do any node handle adjustment operations while using the pen tool (closed path or open path), or using the Shape Editor.
                                  I even removed the "setting.xml" and "workspace.xml" from the "User\Victor\NumericPath\VectorStyler1.0\vector\data\resources" folder to reset the app to the default settings and tried it again with no results. I am on a PC using Windows 11 like @Jayanta-Das.
                                  Jay, perhaps you have a setting enabled to allow that?
                                  If so, I'd be curious to know!
                                  • J Offline
                                    @Victor-Vector Sorry. I was telling about the keys useful in AD and AI.
                                    Wacom Intuos Pro
                                      Victor Vector @Jayanta Das
                                      @Jayanta-Das
                                      Oh, haha, I get it now, thanks!
                                        @Jayanta-Das Closing the path with the Pen tool while also setting it to a Cusp node by holding ALT+ should work now.
                                        • J Offline
                                          @vectoradmin Cusp node can be created by holding ATL but can't drag (node) to make the segment curb at the same time.
                                          Wacom Intuos Pro
                                            @Jayanta-Das Yes, seems to snap to angle also, somehow did not do that in the development build.
