    Understanding pen tool
    50 Posts 8 Posters 140.2k Views 7 Watching
    • J Offline
      Jayanta Das
      I am trying to make an eye shape object with pen tool but I can't without using shape editor tool. Here is the recording. Here is the recording
      Doing Same in AD Recording
      Is this a bug?
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
      VectorStylerV b77B 4 Replies Last reply Reply Quote 0
        VectorStyler @Jayanta Das
        @Jayanta-Das Yes, there seems to be a problem to create cusp (sharp) corners with the Pen tool, at least when closing the path. I add this to the backlog.
          b77 @Jayanta Das
          @Jayanta-Das Btw, you can do the same faster with the Path Sketch tool (shortcut: L):
          alt text
          • J Offline
            Jayanta Das @b77
            @b77 Yes can do but in many circumstances pen is more useful and precise.
            Wacom Intuos Pro
              b77 @Jayanta Das
              @Jayanta-Das Might be. But with the Path Sketch tool you can press Option to redo the last stroke. πŸ™‚
                Hi
                could not resist to bring in my fifty cents
                made with the Pen Tool
                Here the Video
                Eye making in VS
                • J Offline
                  Jayanta Das @Subpath
                  @Subpath QuickerπŸ˜‰
                  https://recordit.co/hfYiCDOv8C
                  Wacom Intuos Pro
                    Subpath @Jayanta Das
                    yes indeed, you are right πŸ™‚
                    But I was not looking for the fastest way, looking just for
                    another possibility with the Pen Tool and I like the shape
                    that emerged
                    • Devil DinosaurD Online
                      Devil Dinosaur
                      Talking about the pen tool... Let's say I want to create a drop shape. When I change a symmetry node into a cusp node using the tool bar (A), I still need to erase manually the tangents handles to obtain this result (B). I avoid the anchor point tool that gives me an unexpected and ugly result (C).
                      alt text
                      I also didn't find how to move separately the 2 handles of a node. In AD or AI I usually press "alt" while moving the single handle but it doesn't work here.
                      Fred.
                      b77B VectorStylerV 3 Replies Last reply Reply Quote 0
                        b77 @Devil Dinosaur
                        If the node is Symmetric and you want to change it to Smooth so that moving one of the control handles doesn't move the other in the opposite direction, select the control handle and press U.
                        If you want to change the node to Cusp, select it or any of its control handles and press L.
                        To change it to Symmetric, press Y.
                          b77 @Devil Dinosaur
                          @Devil-Dinosaur If you wanted to include an image in your post, it didn't upload.
                            VectorStyler @Devil Dinosaur
                            @Devil-Dinosaur To void the result in (C) first convert all corner types to Cusp (before converting to lines).
                              Devil Dinosaur
                              Thank you all, I will try.
                              Am I the only one who can see the image I posted ?
                              Fred.
                                @Devil-Dinosaur If you refer to the image with the A, B and C labels, then that is visible.
                                  b77 @VectorStyler
                                  @vectoradmin Strange… not visible in Brave, visible in Safari and Firefox…
                                    encart
                                    @vectoradmin Photos are not visible on Chrome
                                      Devil Dinosaur
                                      "L" and "Y" and the C conversion work fine πŸ‘
                                      I also use Firefox and Safari, that's why I assumed that everyone could see the picture.πŸ€”
                                      Fred.
                                        Another option is to use the option/alt key on the last point before you let go to complete the loop.
                                        Then you only need to adjust the line a little after
                                          @Jayanta-Das In AD when you draw with the pen tool, after the second node how to you retract the control handle? (when the node changes from circle to square indicator).
                                          • J Offline
                                            Jayanta Das @VectorStyler
                                            @vectoradmin It is same as VS, just click on the node.
                                            Wacom Intuos Pro
