Files saved after VS Beta 1.1 update have no content.
@Qode5 Send them to the developer, no problem.
Beta 1.1.000
I also have experienced no content but only when opening when opening from a file icon.
If I open from the File menu all is ok.
After double clicking the icon I am not automatically taken to Vectorstyler, only any floating panels are displayed.
This happens both when Vectorstyler is already running and when closed and with any previously saved file, ie not just ones created in beta 1.1.
@Jono When VS is opened, it should have the empty application window. Was this changed in preferences?
It might be some conflict with a settings from the previous version.One thing to try: open a file, and open the Canvas&Artboards panel, is there a "Artwork Canvas -> Canvas 1 -> Artboard 1" ?
Here are my preferences for opening documents:
Here are screenshots of the Canvas & Artboards panel. The first is when no content shows, the second is when the same file opens normally:
@Jono send me the file by email that shows no content (to csraba at vectorstyler.com)
I decided to uninstall VS beta 1.1 and reinstall. Reinstall is version 1.0.062. I experienced the same results of a white screen and no content. Not sure if this a Windows issue or not.
I should probably note that the only file I've been able to save in the vstyler file format and open with no issues was an svg file originally created in Inkscape and added to in VS.
@Qode5 It looks like a configuration issue.
Quit VectorStyler, go to the c:\Users<user name>\ folder and delete the "NumericPath" folder (contains VectorStyler settings and workspace).Then launch VectorStyler again.
@vectoradmin deleting the NumericPath folder in the User folder does look to have solved the issue in both 1.0.062 as well as 1.1 beta. I configured VS the way I want and all is working still. Thank you!
@Qode5 Good to hear. If similar issues occur, please let me know.
@vectoradmin Will do. I appreciate the help received from the community here in the 5 days I've owned VS. Looking forward to being part of the VS revolution and escaping the clutches of Adobe.
Cheers!
@vectoradmin just spotted your request for file. Will send in the morning. Thanks.
@Qode5 Could not replicate this issue. Let me know if it still occurs (beta 1.1.002)
