    Vertical text in PDF is not proper
    13 Posts 3 Posters 17.4k Views 3 Watching
    • A Offline
      ash-f
      Tate-chu-yoko text and Rudy text are also in the wrong position.
        VectorStyler @ash-f
        @ash-f is this when exporting to PDF, or from the imported PDF?
        • A Offline
          ash-f @VectorStyler
          @vectoradmin PDF exported by VS.
          • 861475_VctSt8 Offline
            861475_VctSt @ash-f
            @ash-f
            (1.0.062 by MacOS X10.15.7)
            In my environment, they do not happen. (Of course, this is a working screen.)
            This issue should be resolved in ver. 1.0.023.
            LIc. 0 OS10.15.8
            LIc. 1 OS15.7.4
            • A Offline
              ash-f @861475_VctSt
              @861475_VctSt It's not about a problem in VectorStyler.
              Export the artwork as PDF and open it in Acrobat or Preview.
              UPDATE: I just tested on Mac and it's not even shown or opened.
                861475_VctSt @ash-f
                @ash-f
                I don't have that problem in my environment, nor have I been able to reproduce it.
                I have opened it in Acrobat and Illustrator.
                The problem doesn't occur because all the shapes that VS exports are pathified.
                (However, I have another problem where I can't embed a subset without pathing it.)
                Acrobat
                Illustrator
                LIc. 0 OS10.15.8
                LIc. 1 OS15.7.4
                • A Offline
                  ash-f @861475_VctSt
                  @861475_VctSt It could depend on the font used.
                  Have you tried Yu Gothic?
                  Acrobat can't open a pdf KozGo or Noto Sans used on Windows.
                    VectorStyler @ash-f
                    @ash-f I opened a bug on this one, and I will try to replicate it.
                    A 1 Reply Last reply Reply Quote 1
                    • A Offline
                      ash-f @VectorStyler
                      Adobe Fonts(Japanese fonts such as Kozuka, Source Han Sans/Serif ), MS Office fonts(HG, UD Digi/Biz UD), Noto Sans/Serif(CJK) and systems fonts(such as Yu Gothic/Mincho) need to be fixed first.
                      Then we should check other common Japanese fonts later.
                      • A Offline
                        ash-f
                        By the way, improvement for PDF(and SVG) export quality is very important I think.
                        Unless VectorStyler is for "home use" where users can use only it or print to a personal printer, exporting artwork to PDF/SVG is unavoidable in order to share files.
                          VectorStyler @ash-f
                          @ash-f Some CFF based fonts are not exporting correctly to PDF from VS. This is a bug.
                            VectorStyler @ash-f
                            @ash-f Font exporting to PDF and Postscript has been significantly improved in recent versions. Let me know if this issue still occurs.
