    Difficulties making a clipping mask
    3 Posts 3 Posters 4.7k Views 1 Watching
      I want to make the red clip inside the black shape. I have grouped the black parts and also used the combine boolean
      I tried Arrange- Inside Last, and I tried dragging the sublayer under the top layer... what am I missing?
      Here is my video
        @Boldline Are the black shapes combined into one and also grouped?
        Anyway, pasting the red pattern object inside one shape should work (Edit > Paste Inside).
        If however you try to paste an object inside a group of objects, it will just become part of that group, and will not be masked inside those shapes in the group. It's a different behavior.
        So if the black objects are grouped…
        • ungroup them,
        • combine them into one shape with Union, then…
        • move the red pattern over the shape,
        • cut it,
        • select the black shape and…
        • use Paste Inside.
          @Boldline There are two ways to do this.
          One way: as @b77 said, ungroup all black shapes and them combine with Union to create a single clipping shape. Then paste inside, or drag&drop in the layers panel will do the trick.
          The other way: if you want to keep all the black part editable, leave it as a single group.
          • select the black group and select Object -> Object Options and given a name for the group, and then click on Role and select the Shape role and confirm with OK.
          • now we have a shape style that we can use for clipping the other group. And the shape is obtained ynamically by combined the shapes from the black group.
          • select the red group and in the context panel Shape drop down select the shape name given to the black group.
          • this selects the shape style as the clipping shape of the red group.
          BTW: these above steps are very VS specific, I send a basic example by email.
