    Auto-Sizing for Text Frames based on Text Content
    4 Posts 2 Posters 42 Views 2 Watching
    • 861475_VctSt8 Offline
      861475_VctSt
      I have a feature request to improve the Text Frame workflow.
      Currently, our standard Text Tools already handle horizontal auto-expansion naturally as we type. However, I would love to see this "Auto-Sizing" (Auto-Fit) capability extended to Text Frames as well, allowing the frame boundaries to expand or shrink dynamically based on the text volume:
      Auto-Grow Vertically: The frame height expands downward as more lines are added.
      Auto-Grow Horizontally: The frame width expands to the right to fit the text, just like the standard Text Tool does, but while maintaining the properties of a Text Frame (such as text wrapping, padding, and column settings).
      Since I am a designer and not a programmer, I don’t know how the layout engine will calculate these frame boundary changes, but it would be incredibly powerful for creating dynamic labels, badges, and flexible template layouts.
      Could this be considered for the features backlog alongside the other layout markers?
      Best regards,
      LIc. 0 OS10.15.8
      LIc. 1 OS15.7.4
      VectorStylerV 2 Replies Last reply Reply Quote 2
        VectorStyler @861475_VctSt
        @861475_VctSt I will add this to the features backlog
          @861475_VctSt
          If you double clock on the bottom or right resizing knob with the transform tool, then the text frame should be resized to fit the text.
          But not automatic resizing yet, while editing.
            861475_VctSt @VectorStyler
            Thank you for the great tip!
            I immediately tested the double-click behavior on the frame handles. The double-click on the bottom-center handle works perfectly to fit the frame vertically. However, double-clicking the bottom-right or left handles makes the frame lose control.
            Is there any setting in the current Preferences to control or stabilize this behavior? For now, I am more than happy to rely on the bottom-handle shortcut.
            As a non-programmer user, may I suggest a priority for the implementation? I feel that vertical auto-growth is the most critical feature. Since VectorStyler already handles horizontal expansion beautifully with the standard Text Tool, horizontal fitting for Text Frames might be less urgent. Even in QuarkXPress history, vertical fitting was implemented first, and horizontal fit came much later.
            Thank you again for your incredible responsiveness!
            Best regards,
            LIc. 0 OS10.15.8
            LIc. 1 OS15.7.4
