Shape Builder & Bucket Fill Tools' Swatch Iterations
I have the following requests:
- Add swatch iterations to the Shape Builder Tool as you have done for the Bucket Fill Tool.
- Could we have a visual swatch display when using both tools? (Check Illustrator).
Let me expound this request a bit further.
What I meant is that with the Bucket Fill Tool you can now select different multiple swatches using the Shift or Control keys and apply these colours to your artwork by using the Up and Down keys on the keyboard. While this a good addition, you will notice that all the selected swatches remain highlighted and switching to the desired colour is finicky.This function should also be added to the Shape Builder Tool.
Over and above, there is need to implement a swatch pop-up like the one in Illustrator which will then take out the guesswork (as to which swatch will be applied after pressing the Up or Down arrows) as currently exists. The implementation of this function in Illustrator gives you visual feedback when you press the arrow keys and only highlights individual swatches (not all of them at once) such that it's easier for one to pick a desired colour.*
@William-Kansepa I added this to the features list for 1.4
