Imported Shapes lose their edges when Warping
I noticed when I was warping some shapes (formerly text i expanded in Illustrator and imported into VS by copy and paste) that as soon as I clicked on the grouping to warp it, it lost it's definition.
I tested this after i ended the video with native text in VS with no issues and I also converted the text native to VS to curves and then warped it and did not have the same issue. Seems to only be when I import from Illustrator -
@Boldline It looks like the path node types were not copied correctly from Illustrator. What font was used in Illustrator to create the text? I will need to replicate the copying phase.
I used a font called "fresno". I sent you the font file by email
@Boldline This was an AI file format importing issues, that has been fixed.
