Is there a way to align node handles? (one to another)
So I have this node and I'd like to "flatten" it so that the right side handle is in line with the other. Is this possible?
@debraspicher Have you tried holding down the shift key when you drag the node handle on the right side to match the left side?
@Boldline Yes, that's usually what I try first. It moves the right handle in fixed directions (0dg, 45dg, etc)
@debraspicher Select the other control point and use the "smooth node" command (context panel second node type button)
