    update 1.3.012
    6 Posts 4 Posters 52 Views 4 Watching
      (this update was on the 7th of April)
      VectorStyler 1.3.012 release notes
      • Fixed a stroke popover opening issue in the Appearance panel
      • Allow Image Is Mask mode selection in the Appearance panel
      • Added a setting to show original outline in the path editor
      • Do not export default stroke cap and miter modes to SVG
      • SVG exporting to create unique names for objects
      • Color palette panel menu option to allow creating palettes with repeated colors
      • Refresh combined groups when selecting shape combining mode
      • Allow selection of objects with shape roles as blend paths
      • Fixed a bug in the Color Scheme panel
      • Allow importing SVG files with UTF-16 encoding
      • Highlight created preset in the Presets panel
      • Fixed a bug in text layout using fonts not installed in the system
      • Fixed a bug in undoing exclude shape operation
      • Fixed a bug in expanding clipped groups
      • Fixed a bug assigning shortcuts for certain actions
      • Fixed a bug in panel and window docking
      H 1 Reply Last reply Reply Quote 7
      • H Offline
        Harry @VectorStyler
        @VectorStyler Thank you very much for this release!
        @VectorStyler said in update 1.3.012:
        How can I use this feature?
        Changing Artboard's name and using File / Export Artboards with SVG format?
          VectorStyler @Harry
          @Harry said in update 1.3.012:
          This should happen in all cases when exporting to SVG.
          This fixes a bug, where multiple SVG items ended up with the same "id", due to matching object names.
          M 1 Reply Last reply Reply Quote 2
            Subpath @Harry
            @Harry
            You could also look at this post of mine
            where i had a case with multiple Object export as SVG
            https://www.vectorstyler.com/forum/topic/5670/batch-export-export-selected-objects-as-individual-svg-files/3
              monsterfox @VectorStyler
                VectorStyler @monsterfox
                @monsterfox Fixed
