    Alternative Ideas for gradient creation
    6 Posts 3 Posters 33 Views 3 Watching
      Alternative Ideas for gradient creation.
      Vectorstyler offers a lot of Gradient options. But creating multi stop
      Gradients is not really fun. That's why I've collect some ideas to make
      creating multi-level gradients a little easier and fun for users.
      I dont know if those Ideas are really good or well thought but we have
      have to start from somewhere.
      First Idea:
      Create a gradient from a bunch of selected Objects, colored of course.
      Select all Objects and choose create Gradient from selected Objects.
      Gradient Stops can be set evenly, in the direction of objects are created,
      as a user can arrange them later on.
      Second Idea:
      However, for this Idea a obstacle would first need to be removed.
      Vectorstyler currently does not copy colors that appear multiple times
      into a color palette. When creating a color palette from selected objects,
      colors that appear multiple times are only added once.
      See this Thread here:
      https://www.vectorstyler.com/forum/topic/5688/multiple-occurrences-of-the-same-color-are-not-included-when-creating-a-color-palette.
      Oddly enough, duplicating colors in a color palette is possible,
      as is copying the same color to another palette via drag and drop.
      Using the colors from a Color Palette and read them from left to right
      of a color palette was my second idea. The Stops can be set evenly
      for creation as the user can arrange them later
      But this make only sense if the obstacle above is solved.
      Third Idea:
      Create a gradient form a multi blend.
      Multiblends between Objects are already possible in Vectorstyler.
      The start and end Objects could be used as repective gradient stops
      again Stops can be set evenly and user can arrange them later.
      Fourth Idea:
      Create a the colors for Gradient from a bitmap.
      Creating a color palette from a bitmap is already possible.
      I think it would be nice to have this for Gradients too.
      The user should be able to choose how many Gradient Stops he like
      to have and VectorStyler should create the Gradient accordently
      from a Bitmap.
      VectorStylerV E 2 Replies Last reply Reply Quote 1
        VectorStyler @Subpath
        @Subpath For the 1.4 backlog
        • E Offline
          EricP @Subpath
          @Subpath or simply :
          • select multiple colors from palette and drag them onto the gradient panel : places them in the order selected on gradient scale
          • alt-drag : add additional colors to existing gradient as more stops, including already used colors
          S 2 Replies Last reply Reply Quote 1
            Subpath @EricP
            @EricP
            I'm open to additional ideas; they're welcome.
            But selecting colors in the palette first and then drag and drop
            them into the Gradient panel seems a bit cumbersome.
            If I could simply use "Create Gradient from Color Palette" instead.
            One of my main ideas for this whole thing is actually "Create Gradient from selected Objects."
            This would allow me to use larger color areas with larger objects, giving me a better impression
            of the colors. Selecting colors and choosing colors in the Gradient Panel or the Color Panel is
            a bit too fiddly in my eyes.
            Yes, you could copy Gradient Stops via the ALT Key which is nice to have.
              Subpath @EricP
              @EricP
              After further attempts, I understand your suggestion that
              colors from the color palette can already be transferred
              to an object with a gradient via drag and drop.
              Dragging and dropping selected colors from a palette into
              the gradient editor doesn't work.
              At my first attempts i was slightly misleading because the
              object with the gradient initially became a solid fill at first.
              However, when you then apply the gradient via the gradient tool
              to this object again, the gradient with the selected colors appears.
              So, thanks for this tip.
                Here a step by step guide for other Users:
                How to use colors from a color palette for gradient colors
                Create or select an object with a gradient.
                Select the colors in a color palette while holding
                down the Shift or Ctrl key (Windows).
                Drag and drop the colors from the color palette onto the object
                with the gradient.
                The object's fill will change to a solid color.
                Drag the gradient again with the Gradient Tool, and
                the gradient will now display the colors you selected.
