    Impressions about CJK implementation (1.0.023)
    19 Posts 3 Posters 12.2k Views 3 Watching
    • 861475_VctSt8 Offline
      861475_VctSt @VectorStyler
      I would like to upload a movie on this matter.
      However, I can't, so I'll attach it by email.
      LIc. 0 OS10.15.8
      LIc. 1 OS15.7.4
        VectorStyler @861475_VctSt
        @861475_VctSt For the video it is better to use some service like recordit.co , or share it through drop box.
          (by 1.0.024)
          The mojikumi sample is ready. However, there were some obstacles that prevented me from starting work. Also, I manually trimmed the parts of VS where the corresponding function was not normal.
          a) Japanese input cannot be performed normally
          b) Some system fonts are not recognized.
          c) Character and paragraph styles do not work together correctly for reasons b)
          Avoiding problems b) and c) with vendor fonts improved style coordination. Then I started working.
          The body of the text was assembled very neatly.
          Skill was required for "ruby", "emphasis mark", and "warichū" processing. I will continue to examine and report on these in more detail.
          Especially, "ruby" and "character set" are complicated. It will be difficult to complete with Ver1. As long as the basics of these functions are established, I think that it should be improved by version upgrade.
          I also found that these processes could be replaced by VS's "individual characters tool (Shift + T)".
          VS Ver1 will implement features that Illustrator has put on hold for "more than 30 years." It may be a dream only for Asians, but I am very grateful for the enthusiasm of the developers.
          We need more people's opinions to realize the product.
          LIc. 0 OS10.15.8
          LIc. 1 OS15.7.4
            @861475_VctSt What are the system fonts with the problems?
              Primarily
              / System / Library / Fonts
              What cannot be used here
              HiraginoKakuGothic W0 ~ W9.ttc
              HiraginoMaruGothicProN W4.ttc
              Secondly
              System fonts quarantined by macOS version upgrade
              There are many other pre-Yosemite fonts out there.
              / System / Library / AssetsV2 / com_apple_MobileAsset_Font6
              YuGothic-Medium.otf
              ToppannBunkyu
              TukushiAmaru
              TukushiBmaru
              Yumintyou
              Hannoteto
              etc. lots
              VS is reading these in Manager.
              However, these were evacuated by Apple's policy, so they probably cannot be used commercially due to copyright issues.
              I recognize that it is better not to use it for anything other than screen display.
              This matter requires accurate confirmation.
              LIc. 0 OS10.15.8
              LIc. 1 OS15.7.4
                @861475_VctSt An other way to add fonts to VectorStyler, without installing it into MacOS:
                • copy the fonts into a a user created folder (can be anywhere).
                • select Font Manager in the Text menu (somewhere at the bottom).
                • click Add Folder and select the user folder created earlier.
                In this way VS can access the fonts, without installing it to the system. Of course it only works if VS recognizes the font format.
                  Report on the following items (ver.1.0.027)
                  x) Japanese conversion bug
                  a) tate-chu-yoko
                  b) kenten
                  c) shatai
                  d) ruby
                  e) warichu
                  f) mojikumi
                  g) kinsoku
                  Material data (up to cloud)
                  -Input bug: mov
                  -Document: VS
                  x)
                  issue: Blanks are entered when using the input mode selection keys (eiji, kana).
                  Corrective action: It should be corrected so that blanks are not input when switching the input mode. (Cf. Mov)
                  Other previous issues have been fixed.
                  a)
                  issue: A little space appears on the characters.
                  Isn't the origin of the alphabet aligned with the full-width frame?
                  First-aid measures: Shift up to about 200/1000 and resolve.
                  b)
                  Unfinished, but durable for general use.
                  issue: The default character is not partially reproduced. Dot, Fill Circle, Lozenge
                  Character input does not fully support Japanese "itaiji".
                  It's a feature that isn't used often, so I think it's better to mature it over time.
                  c)
                  Horizontal composition: adjust rotation has been fixed.
                  Almost completed
                  d)
                  Generally good.
                  groupe> center: As a graphic application, it would be great if this could be done. After that, I think that it should be aged over time.
                  Items to consider: Need to visualize the subsumption relationship of nested setting items.
                  Inclusive relation display of nest items such as Font and Size is not implemented.
                  I want you to be able to see it.
                  When Rubi is set in VS, if "Arial" is displayed in the dialog, it will be ignored if it is set to HugenoMin in character style.
                  In InDesign, inherited items are displayed as horizontal bars or blanks.
                  Ideally it should be like this.
                  This issue is the same for kenten.
                  e)
                  issue: Horizontal composition; Aligned with the European baseline. It appears to shift above the full-width center.
                  f), g)
                  Incomplete but working fine. I think it would be good to take time to complete the aging.
                  These features are important.
                  However, only some people, such as typesetting team leaders and font designers, can customize it accurately. General users divert those made by these trusted people.
                  General request
                  When using the text tool, the function once used is inherited.
                  I want a function to clear all at once.
                  LIc. 0 OS10.15.8
                  LIc. 1 OS15.7.4
                  VectorStylerV 861475_VctSt8 3 Replies Last reply Reply Quote 1
                    @861475_VctSt Send me a link to the cloud files. Thanks!
                      861475_VctSt @861475_VctSt
                      @861475_VctSt
                      The above post is
                      It should have been uploaded to "CJK, Japanese observation (1.0.024 ~)".
                      Next time, I will create a new topic. Please read as it is.
                      LIc. 0 OS10.15.8
                      LIc. 1 OS15.7.4
                        said in Impressions about CJK implementation (1.0.023):
                        x)
                        I had overlooked it, but I reported it again as a bug via email.
                        LIc. 0 OS10.15.8
                        LIc. 1 OS15.7.4
                          @861475_VctSt I will try to replicate and fix this
                            Thanks.
                            t's working properly.
                            My years of frustration have been resolved.
                            LIc. 0 OS10.15.8
                            LIc. 1 OS15.7.4
                            861475_VctSt8 1 Reply Last reply Reply Quote 1
                            • debraspicherD Offline
                              debraspicher
                              I decided to test this. Can report pre-conversion shows up as blanks momentarily in Windows 11 also and input is rather clunky. This is with version 1.3.011
                              Several issues:
                              1. Text input is lagging in general with output
                              2. Fonts can't be changed when textbox is empty. I don't remember this being an issue in the past.
                              3. Textbox can't be activated sometimes and even when appearing to be activated, doesn't take input (with the text caret icon visible with mouse).
                              4. The user has to look for the IME conversion window to the lower left of the program to see which candidates are available. It should be appearing closer to the text.
                              5. The conversion box moves back up towards the text if you try to adjust pre-converted text. This isn't true if starting a new sentence at the end of a line.
                              6. If there is a delay with converting a character, if you are still typing after that (say entering a "."), it completely misses that input and so the next word/character has to be redone.
                              Video showing all the problems (has audio):
                              https://1drv.ms/v/c/110a6c79485f87e5/IQCksyZcydqUQ5U-xDVe-D88AWZ28xBa54ZwsZWNIcB1Sj0?e=UsqE9a
                              32GB RAM @ 6000MHz
                                @vectorstyler
                                @debraspicher
                                I watched the video. With my language skills, I couldn't catch what was being said and couldn't fully understand it.
                                In short, it's about IME-related behavior being unstable, right?
                                I understand that the Japanese IME issue was resolved in 1.3.011, and I'm reasonably satisfied with that.
                                Is the issue you're presenting from 1.3.011 onward, or was it present before that?
                                Are the following settings configured?
                                ・Preferences > Applications > East Asian Options > ON
                                ・Character Styles > Script > CJK
                                These settings are essential beforehand when working with Japanese text. It's also highly recommended to create Japanese-compatible character styles. On top of that, I suggest creating a template that includes these settings and working from it.
                                @Vectorstyler
                                I raised this issue in April 2021—five years ago. I'm a user in the specific environment of "Japanese." Furthermore, no other users reported this issue. Therefore, at that time, I judged that improving this issue offered little benefit to overall development and held off requesting a fix until VS development stabilized.
                                It's an issue that could be resolved by me removing a single space.
                                Five years have passed since then. VS development seems to have entered a stable phase, so I resubmitted this issue and believed it had been resolved. However, due to the small number of Japanese users, I haven't been able to gather other opinions. Let's continue monitoring this matter.
                                LIc. 0 OS10.15.8
                                LIc. 1 OS15.7.4
                                861475_VctSt8 debraspicherD 2 Replies Last reply Reply Quote 2
                                  Japanese Typesetting Reference Materials (Since I might forget myself)
                                  https://
                                  www.w3.org/TR/jlreq/?lang=ja#legend_of_table_3
                                  LIc. 0 OS10.15.8
                                  LIc. 1 OS15.7.4
                                    VectorStyler @debraspicher
                                    @debraspicher @861475_vctst I will try to replicate these and fix if possible.
                                      debraspicher @861475_VctSt
                                      @861475_VctSt お返事にありがとう~ その設定でもう一度見ます。
                                      しかし、IMEでなく英語入力したらある問題もみえるし、リポートすることも必要だと思います。
                                      32GB RAM @ 6000MHz
