    How can I delete an anchor point from a path while preserving the curve?
    4 Posts 2 Posters 20 Views 2 Watching
    • K Online
      Kumr
      Guess this has been addressed before but couldn't find it in the search. How to remove specific nodes while keeping the curvature intact? Illustrator has Shift + select option, not perfect but works in most cases.
        VectorStyler @Kumr
        @Kumr Select the node and press the Delete key. In VS the default node deletion will keep the path connected and preserve the curve as much as possible.
        K 1 Reply Last reply Reply Quote 1
        • K Online
          Kumr @VectorStyler
          @VectorStyler Thanks. The paths are drifting a bit in most cases. Any setting I have enable to make it best of it? Also Node removal tool not working. I click on the node, but nothing happening.
          Thanks
            VectorStyler @Kumr
            @Kumr said in How can I delete an anchor point from a path while preserving the curve?:
            This depends on the path, some adjustment is made. Send me an example.
            No options for this.
            With this tool you have to paint over nodes.
