    Connect Tool
    15 Posts 6 Posters 97 Views 6 Watching
    • 861475_VctSt8 Offline
      861475_VctSt
      I frequently draw mind maps and flowchart-like diagrams in my daily work. Since this task isn't well-suited for VS, I use CorelDraw or other dedicated applications.
      If possible, I would like to see a Connect Tool implemented in VS as well.
      Beyond flowcharts, it could also draw Mondrian-esque patterns.
      LIc. 0 OS10.15.8
      LIc. 1 OS15.7.4
      VectorStylerV L 2 Replies Last reply Reply Quote 3
        VectorStyler @861475_VctSt
        @861475_VctSt I added this to the features backlog
        L 861475_VctSt8 2 Replies Last reply Reply Quote 0
        • L Offline
          Li Xiao @VectorStyler
          @VectorStyler This is the online circuit board pattern generator (https://codepen.io/msurguy/pen/YPWZqoe).
          It would be great if the Repeater could generate circuit board patterns with variations in the intensity of the background image.
            861475_VctSt @VectorStyler
            deally, I'd like something that lets me freely draw each line by hand, rather than generating them by entering values on a panel.
            It would also be nice if I could input text along the lines.
            I'm eagerly awaiting it.
            LIc. 0 OS10.15.8
            LIc. 1 OS15.7.4
            • L Online
              larsherold @861475_VctSt
              @861475_VctSt
              Earlier I used OmniGraffle, https://www.omnigroup.com/omnigraffle
              for charts, diagrams, interface dialog structure and simple PCB-routing. Beautifully crafted software, check it out! Mac only though...
              BR/ Lars Herold
              861475_VctSt8 1 Reply Last reply Reply Quote 2
                @li-xiao , @861475_vctst
                i like to add that you are able to create your own "Arrowhead"
                in vectorstyler
                select your Design for the arrow head and go to
                Menu > Styles > Create Styles > Create Arrow Styles
                dont remember which one was better Preset or Style
                but i manage to create a circuit like stroke this way
                • L Offline
                  Li Xiao @Subpath
                  @Subpath
                  Thank you for the tips.
                  What I'm looking for is unrelated to the theme; it's not a manual operation. I want to automatically generate circuit board pattern in a regular or random pattern based on the variations in intensity of background shapes or images, similar to the numbers and horse images I recorded in my video.
                  https://youtu.be/i2g5R4UiS7g
                    Subpath @Li Xiao
                    @Li-Xiao
                    This looks cool and interesting.
                    I tried something, like your pics a while ago
                    in "Paragraphic" but could never solve how to do it.
                    • L Offline
                      Li Xiao @Subpath
                      @Subpath said in Connect Tool:
                      @Li-Xiao
                      Creating this kind of effect in VectorStyler is very simple and convenient.
                        861475_VctSt @larsherold
                        @larsherold
                        I've been using OmniGraffle since version 3 (OG) for over 20 years now. Diagrams created in OG can be copied and pasted into VS as vectors. (In my case, since it's Japanese, the text gets garbled and is completely unusable.) While OG is a useful tool to have, it just doesn't feel natural to me.
                        When drawing flowcharts, I mainly use a low-cost software called VisualDesigner2. It has a pre-modern UI, but the operation feels familiar. (This cannot be copied and pasted into VS.)
                        Anyway, my approach is not to generate with a generator, but to draw, adjust the balance, draw again............ a very 20th-century style of operation.
                        @Li Xiao
                        @Subpath
                        On the other hand, I don't use software that generates complex shapes with generators much, as my field is different.
                        Recently, there's FontLab's VEXY LINES, for example.
                        https://
                        www.vexy.art/lines/
                        LIc. 0 OS10.15.8
                        LIc. 1 OS15.7.4
                        S 2 Replies Last reply Reply Quote 2
                          Subpath @861475_VctSt
                          @861475_VctSt
                          Thanks for the tip.
                          I think much, if not everything, that "Vexy Lines" offers is possible with
                          the Repeater in Vectorstyler.
                          Paragraphic is similar as well. But I'll definitely take a look.
                          Because that's exactly my area; I like to experiment. 🙂
                            @861475_VctSt
                            Here a Tip, Diagram related.
                            The "yEd" Graph Editor is a free java based Diagram App.
                            (Win, Mac, Linux)
                            Here a Link
                            https://www.yworks.com/products/yed/download
                            • E Offline
                              EricP
                              Yes connectors would be a great addition to VS. Ones that stay connected to the shape or path when it is moved and keep a fixed angle to the normal of the connected path.
                              You can find various connector styles in draw.io
                              https://app.diagrams.net
                                861475_VctSt @EricP
                                @EricP
                                Thanks for the useful site info.😃
                                It's a handy web app.
                                @vectorstyler
                                When implementing it in VS, I expect something beyond PowerPoint.
                                When lines intersect, the detour method is crucial.
                                LIc. 0 OS10.15.8
                                LIc. 1 OS15.7.4
                                  @861475_VctSt said in Connect Tool:
                                  That can make it more complicated.
