    Queries Regarding VectorStyler 1.3
    59 Posts 6 Posters 11.5k Views 4 Watching
    • S Online
      Subpath @monsterfox
      @monsterfox
      Glad it was helpful.
      My understanding of the repeater's capabilities is also still quite limited.
      I just experiment with it now and then and gradually expand my knowledge.
      • E Offline
        EricP @VectorStyler
        @VectorStyler said in Queries Regarding VectorStyler 1.3:
        This can be done with a number variable for the tilt amount and then controlling the variable using the backdrop intensity as a repeater adjustment
        I've noticed that shape transform parameters (the ones that appear in Properties panel) don't seem to accept number variables as input.
        Also, adding a shape effect Transform allows to use number variables as input, but they seem to have no effect.
        I don't know if this limitation is intended or not but it would be nice to be able to use number parameters on Transform parameters
          monsterfox @VectorStyler
          @VectorStyler I enabled the skew option in the Repeater, but the skew angles of the repeated shapes are very inconsistent and messy—this should be a bug, right?
          倾斜错误.vstyler
            VectorStyler @monsterfox
            @monsterfox I try to find out what can cause this
              @monsterfox said in Queries Regarding VectorStyler 1.3:
              The Skew adjustment was set to Randomized mode in the Geometry Adjusments. You should select Backdrop Content.
                @VectorStyler 文件破坏.zip This is a corrupted file and it’s not important. It was likely caused by severe lag. I’m attaching this file just to see if you can repair it, and also hoping you can optimize the lag-related issues in the future.
                  @monsterfox The file cannot be recovered as its saving was not completed.
                  What feature caused the lag?
                    @VectorStyler There are numerous objects here that are all paths with a large number of nodes, and moving them is quite laggy—just like the previous graphics. Such paths can be moved completely without lag in Adobe Illustrator. It seems you haven’t yet figured out a solution for these types of paths. Keep it up!
                      @VectorStyler Here’s a thought regarding corrupted files: is it possible to address these two scenarios?
                      1. The program crashes during saving due to lag.
                      2. A sudden power outage occurs while saving.
                      Both cases can corrupt the file, making it unopenable – the loss can be devastating when dealing with important files.
                      For these two scenarios, could the save operation be designed to take effect only upon full completion (i.e., the save is recorded only after the entire saving process finishes)? While a minor amount of recent data might be lost in the event of a crash or power outage, the file itself would remain uncorrupted, allowing for partial recovery of the content.
                        This this is doable. I will open a bug on this and do it as soon as possible.
