    Redrawing part of a path with the pencil tool
    11 Posts 3 Posters 782 Views 3 Watching
      Subpath @Raven
      @Raven
      not sure if i understand this right
      but wouldnt the "Path Sketch" Tool work for that ?
      (its right beside the Pencil Tool)
        VectorStyler @Raven
        @Raven What was the direction of drawing with the pencil tool?
        Send me those shapes in a VS file, I will try to replicate it.
        • R Offline
          Raven
          VS file attached
          0_1767857815660_Redraw parts of a path.vstyler
          Looking at the Path Sketch tool now.
          tries...
          tries...
          Thanks Subpath. You are right - the Path Sketch tool can do this.
          I didn't know it can be used to modify closed shapes that were already created by other tools, eg Pencil.
          Reshaping using the pencil tool is still useful whilst in the process of creating shapes with the Pencil tool, to avoid frequently changing tools.
          Now to find an equivalent to FreeHand's Freeform tool.
            VectorStyler @Raven
            @Raven said in Redrawing part of a path with the pencil tool:
            Is this a 4-point transform tool?
            VS has a 4-point distortion non-destructive shape effect
            • R Offline
              Raven
              @VectorStyler said in Redrawing part of a path with the pencil tool:
              The Freeform tool is an adjustable size circle that can be used to "push" paths, in or out. It's destructive.
              It is similar to VS's Path Brush tool when used starting inside a closed path, adding area to the shape and smoothing the transition points.
              It can also be used starting from outside a closed path to push the touched area in, creating new nodes as required.
              I don't know how to do that in VS other than by using the Redraw with Pencil function, or now, the Path Sketch tool, but they both work by drawing the replacement path section - a different experience to simply pushing the outline around like clay.
              Have experimented without success so far with VS's Eraser tool, the Path Eraser tool and the Reshape tool. May be a setting or modifier key I've not found.
              0_1767868705176_Freeform tool help.pdf
                VectorStyler @Raven
                @Raven Closest I can think of is the Liquify tool in VS
                  Subpath @Raven
                  @Raven
                  Sounds a bit like the Nudge Tool in "Concepts" too me
                  Here a video (Concepts for Windows)
                  (ignore the video title)
                  the liquify tool in VS is similar
                  • R Offline
                    Raven
                    @Subpath
                    The Nudge Tool in "Concepts" looks like the FH Freeform tool. Right down to the real-time preview of the resultant path and the tendency to smooth out what it contacts.
                    I haven't been able to get VS's Liquify tool to act the same. It is pulling paths around instead of pushing them (hard to explain that concept) and generating many nodes and spiky shapes. There are lots of settings there so I will experiment.
                    The Path Brush tool in VS could suffice for most work, even though seems to be limited to closed shapes has no smoothing, if only it could work in reverse when dragged from outside the shape - subtracting area instead of adding. Is that possible?
                    S VectorStylerV 2 Replies Last reply Reply Quote 2
                      Subpath @Raven
                      That's interesting to know.
                      Yes, the Liquify tool doesn't quite measure up.
                      I have a copy of Corel Draw 2020.
                      It has a tool called "Attract and Repel." which works also quit nice
                      See Video here
                        VectorStyler @Raven
                        I added the Freeform tool to the 1.4 feature backlog
