update 1.3.006
    VectorStyler 1.3.006 release notes
    • Improved precision in offset stroke stripe
    • Improved stroke rendering speed
    • Improved brush handling on complex shapes
    • Top down coordinates to align page grid to the page top left corner
    • Improved 16-bit BMP support
    • Improved magic wand tool
    • Added a palette panel menu command to expand spot colors of selected objects
    • Show scaled font sizes in the Character panel when selecting text inside scaled groups
    • Detach clones before ungrouping the clone source
    • Allow custom shaped corners when one corner side size is set to zero
    • Shift+Click should deselect single object selections
    • Added an option to the style picker tool to select objects or groups
    • Shape conversion should keep object position
    • Return to normal object selection after exiting the text editor
    • Initial line to be shown correctly in the polygon selection tool
    • Fixed a regression in the font manager view
    • Fixed a regression in creating color presets
    • Fixed a preview issue in the modal contour view
    • Fixed a bug causing objects to be selected multiple times
    • Fixed a bug in distorting 16-bit RGB images
    • Fixed a bug in selecting color for the paragraph bullet symbols
    • Fixed a bug in selecting symmetric randomization in the Move command
    • Fixed a bug in extending paths with the line tool inside transformed layers
    • Fixed a bug in undoing multiple repeater expansions
    • Fixed a bug in changing selection while using the Anchor tool
    • Fixed a bug in working with large number of objects in the Appearance panel
    • Fixed a bug in handling unit names in math expressions
    • Fixed a bug in the Simplify Path command with Node selections
    • Fixed a bug in adding stroke to selected text from the Stroke panel
    • Fixed a bug in handling vector brushes
    • Fixed a bug in expanding vector brushes on small shapes
    • Fixed a bug in selecting shape presets for the Bend effect
    • Fixed a bug in using the Style Picker tool after the Node tool
    • Fixed a bug in placing cloned objects outside of layers
  • @VectorStyler Thanks for fixing the cloned object bug
  • @VectorStyler thank yo for this quality update with lots of fixes
  • @VectorStyler Impressive list of improvements! Thank you for your continuous efforts to improve VS. version 1.3 gets better all the time
