    Dedicated line halftone option for the new halftone tool and repeater
    11 Posts 3 Posters 1.1k Views 3 Watching
    • L Offline
      Li Xiao @Boldline
      @Boldline The line halftone is already included in the vector halftone.
      0_1765856978433_line halftone.vstyler
        @Li-Xiao Thanks@ obviously I had no gotten far enough into 1.3 in these areas!
        • L Offline
          Li Xiao @Boldline
          @Boldline You're welcome! 1.3 has so many surprises regarding vector halftoning.
            @Li-Xiao Did you see a way to make the color in the halftone stay a solid black for example? Right now I'm getting a fade from black to grays
            0_1765864352065_f67d066f-8fe5-42dc-8f8f-f9ec9ef4078a-CleanShot 2025-12-16 at 00.50.17.png
            • L Offline
              Li Xiao @Boldline
              @Boldline said in Dedicated line halftone option for the new halftone tool and repeater:
              solid black
              From your screenshot, itโ€™s because you overlayed a transparent gradient, which is why itโ€™s not solid black.
              0_1765866104227_solid black.vstyler
                Boldline @Li Xiao
                @Li-Xiao thank you! it seems the more I learn about VS, the more I realize I need to dig deeper into learning
                • E Offline
                  EricP
                  you may change colorize mode from Backdrop Content to None
                  • L Offline
                    Li Xiao @EricP
                    @EricP
                    I also noticed the Clorize option.
                    In the screenshot, you can see a noticeable four column effect due to the Length Limit value.
                    If Clorize is set to Backdrop Content, the gradient will not be smooth.
                    I'll create an example to illustrate this clearly.
                    0_1765899226155_line halftone.vstyler
                    E 1 Reply Last reply Reply Quote 1
                    • E Offline
                      EricP @Li Xiao
                      @Li-Xiao thanks for this. I did not investigate all the halftone settings yet.
                      Looking at the file you shared, it seems the vertical banding can be adjusted by changing the length limit parameter.
                      By increasing it to 150mm, the gradient is now smooth. I guess it cuts lines in different segments when the line exceeds the length limit
                      • L Offline
                        Li Xiao @EricP
                        @EricP A larger Length Limit value does not improve color sampling accuracy, @VectorStyler Image halftoning is the perfect solution.
