    Quick radial tool
    11 Posts 5 Posters 1.5k Views 4 Watching
    • EvaeloE Offline
      Evaelo
      Maybe even better is to invoke mirrored (or radial mirrored) mode adjust\set a centre point (or line) and start designing.
      If the object crosses the point\line of symmetry (mirror line) to get 'non-destructively cropped' (masked?) Is it actually the same thing → non-destructive cropping = masking?
        @Boldline The mirror tool can do something like this with increasing the axis
          FastVector
          Here a quick snowfloke with Repeater along path
          Windows 10 | 1920x1080 | 125%
          • DanielD Offline
            Daniel
            I have to once again call your attention to FreeHand's absolutely wonderful mirror, rotate and duet function with a dedicated dialog box to decide the number of axes too. I'll post a gif tomorrow.
            • DanielD Offline
              Daniel
              This post is deleted!
              • DanielD Offline
                Daniel
                https://ibb.co/JRmjQVfJ - Check this out.
                • DanielD Offline
                  Daniel
                  The gif I posted is from FreeHand, which pioneered the mirror tool originally. What's great about it is that unlike Irritator which is a modal window that has to be called back repeatedly to apply the transformation, FreeHand allows to successively apply the transformation once you've decided the number of axes. FreeHand really sucks at snapping though. It has virtually no smart snapping, and object snapping is pretty shite, which means you have to eyeball the edges. But otherwise, it is remarkably sophisticated. Allows you to very rapidly create tiling clones. You can also apply a duet transform to your original object. A duet acts like a symbol, except that it undergoes every transformation that your main object goes through. Including every change of attribute including position. It is very useful.
                    would creating something like this fall under a mirror feature or a repeater tool function or both?
                    I'm wondering if repeater needs a "radial" option as one of the geometry opitions?
                    0_1764946326281_7f3b1fe3-17f4-4f7a-87d2-76673ba6927b-CleanShot 2025-12-05 at 09.47.49.png
                      FastVector
                      'I'm wondering if repeater needs a "radial" option as one of the geometry opitions?'
                      @Boldline Do you mean something like this?
                        FastVector
                        Just played a little around with this. Here a video how you can easily change the shape that is in the repeater
