    VectorStyler 1.3.001
    34 Posts 12 Posters 12.9k Views 9 Watching
      Regarding presets and settings: 1.3 will start with default settings, workspace and presets, this is needed to have the new features available (ex. customized toolboxes will not show new features)
      Previous presets can be copied from the user data folder.
        Subpath @VectorStyler
        I would also like to express my appreciation for the work you put
        into the 1.3 update. So, a deep bow from me for that.
        I recently switched to a new PC, so this update is doubly enjoyable.
        Congratulations on this milestone ! 👍
        • W Offline
          William Kansepa
          @VectorStyler I am deeply grateful for this amazing update!!! Echoing what @Boldline has said, this will indeed take VS to the next level!!!
            VectorStyler @Daniel
            @Daniel About the Bezigon tool: the default mode will draw lines and Option(Alt)+ will draw curves. This can be changed with the ""Draw Curves in Bezigon by Default"" in Settings -> Other Options
            • A Offline
              achillepr
              Just bought it. I don't use it much, I'm an amateur, but I do it mostly to support this wonderful program and its creators. Thank you.
              VectorStylerV 1 Reply Last reply Reply Quote 7
                VectorStyler @achillepr
                @achillepr said in VectorStyler 1.3.001:
                Thank you.
                  in the Windows version the desktop shortcut and menu name was not updated to 1.3.
                  This is now fixed.
                  debraspicherD 1 Reply Last reply Reply Quote 3
                  • debraspicherD Offline
                    debraspicher @VectorStyler
                    @VectorStyler Yes I was coming to report this
                    32GB RAM @ 6000MHz
                    • A Offline
                      ai_slop
                      Looks impressive. Thanks for your hard work
                      • E Offline
                        EricP
                        Yes, a truly impressive release with a lot of unique features you don't find elsewhere. I still haven't found how they all work but I am so far delighted by what I saw. Thank you
                        • syllieS Offline
                          syllie
                          The one day that I did not check the forum and boom there it is! I am so excited to give this version a spin. Thank you so much @VectorStyler for your continuous efforts to make this such a good vector editor. I am going to run it yet again through my 'how does it stack up for SPD work' check. So happy that I have a quiet time coming up to check this all out!
                          Windows 10 Pro | 22H2
                          • K Offline
                            Kumr
                            Thank you for the update. Packed with great set of tools for easy workflow and design.
                            • E Offline
                              EricP
                              this new Arc Tool. What an absolute joy to use !!
                              • L Offline
                                lilith
                                I can't find the roadmap, please send me a link
                                  VectorStyler @lilith
                                  @lilith said in VectorStyler 1.3.001:
                                  I have taken it down because it is mostly not valid anymore. A lot have been done in 1.2 and 1.3 and I need to update it.
                                  • E Offline
                                    EricP
                                    @VectorStyler Could you please explain how to use the new Extract Path Sections tool ? I tried it but could not find how it works
                                      VectorStyler @EricP
                                      @EricP Paint with the tool over a path section between 2 intersections with other paths.
                                      E 1 Reply Last reply Reply Quote 0
                                      • E Offline
                                        EricP @VectorStyler
                                        @VectorStyler yes, that's what I tried. It paints a thin red line but does nothing else. I can't record a video right now to show you
                                          VectorStyler @EricP
                                          @EricP I will open a bug and will try to replicate the issue. If you have a file where that you can send me it can help.
                                          • E Offline
                                            EricP
                                            @VectorStyler here is a file : 0_1764166229302_extract path sections.vstyler
