    Random selection
    16 Posts 4 Posters 6.9k Views 4 Watching
    • E Offline
      EricP @Subpath
      @Subpath said in Random selection:
      In case you dont know, Colorize allows also to randomize
      Outlines or Fills only.
      That's a good idea. I did not think of using stroke color for this. Smart !
      I will try
      Thanks
        Subpath @EricP
        @EricP
        Smart ? Thats not me 🙂
        Found this by Accident.
        I am just curious and like to experiment.
        @VectorStyler is the smart guy 🙂
        • E Offline
          EricP
          @vectorstyler I noted you included this request in backlog. Thank you for that.
          I’ve been using Vectorstyler a lot since I submitted that request and I still feel this feature would really add a lot of value. Maybe after 1.3 ....
          Some suggestions on possible implementation options :
          • a dedicated panel seem needed
          • a percentage value determines how many objects get selected out of the total
          • limit to current selection option : when ticked considers only objects currently selected, for random selection. When unticked considers all objects in document/layer/artboard/view
          • seed button/value changes the seed for random selection, the selected objects are highlighted
          • select button : performs the selection, the selected objects are highlighted
          additional « nice to have »
          Pattern selection
          • select every n/m object : example "select every 2/3" selects 2 objects every 3 objects. Allows for repetitive pattern selection
          • sort by : object index (the order by which objects were created), layer order, left to right position, top to bottom position, radius from center : defines the sorting criteria for applying the n/m selection
          • offset : allows to shift the first object selected out of the m subset
          Nodes
          • select nodes : with this option ticked, allows random selection of nodes across multiple objects (so we can move them, or change their type …)
          Thanks
            VectorStyler @EricP
            @EricP The random selection will in 1.3, as for the rest, not sure yet. These are easy to do (and can be very useful), but time is limited for 1.3
            E 1 Reply Last reply Reply Quote 0
            • E Offline
              EricP @VectorStyler
              @VectorStyler oh wow that's great ! I wasn't even expecting it for 1.3.
              I will wait patiently 🙂
              Thanks !
                Subpath @EricP
                @EricP
                Did you ever had a look at "Paragraphic" (PC/Mac) it may be
                helpful in some cases. As i like to experiment, i find it a nice
                companion besides VectorStyler. Results made in Paragraphic
                could be easely copied via the Clipboard into VectorStyler.
                It offers also a few possibilities for Pattern selection,
                which my not be direct helpful but maybe indirect.
                Here a Thread of mine
                https://www.vectorstyler.com/forum/topic/4786/paragraphic-from-lost-minds-software-is-avaible-now
                Here a Video about pattern selection
                • E Offline
                  EricP @Subpath
                  @Subpath yes I have been using paragraphic for a while and it is indeed a great tool and beautifully designed software. It is great for nested repeaters and geometric patterns
                    Subpath @EricP
                    @EricP said in Random selection:
                    Indeed it is a nice companion to VS.
                    I'm currently experimenting with the Layer node, which allows
                    coloring vector objects using a bitmap.
                    Here's a video for anyone interested.
                    • L Online
                      Li Xiao @Subpath
                      @Subpath
                      which allows coloring vector objects using a bitmap.
                      Using the Repeater’s Region or the Colorize (Effects menu) Region to color vector objects is also very convenient. I use them often and recorded a video for your reference.
                      https://youtu.be/tTQzzOugq9A
                        Subpath @Li Xiao
                        @Li-Xiao
                        WOOOW! 🙂
                        Cool, will take a look and a
                        big thanks for making the video 👍
                        • E Offline
                          EricP
                          @Li-Xiao thanks for the video ! That's funny, my next YT tutorial is about colorizer function and I'm also going to demonstrate the region coloring mode, which I like the best. I like the trick about clipping the image to adjust zoom and pan of reference image, that is smart.
