      FastVector @Boldline
      @Boldline For me this is only working when I'm using the node tool and then I've to double click on a existing node. (I quess something different in my settings for the pen tool)
      Windows 10 | 1920x1080 | 125%
        VectorStyler @FastVector
        @FastVector said in XLS for features and ideas - Megathread:
        Could be a settings issue. Send me your workspace/settings files (Help -> Reveal Workspace).
          Subpath @FastVector
          @FastVector
          Made a little Video here
          Using Ctrl+a while the Node Tool is selected
          will select all Nodes of a Shape.
          • DanielD Offline
            Daniel
            How about single clicking curve to add a node. Double clicking a node to delete the node?
              Subpath @Daniel
              @Daniel
              A single click to add a node seems too risky to me, since its
              used to select a section of a path, and it's easy to click accidentally.
              And double-clicking a path to delete a node?
              I'm not really convinced.
              A modifier key to delete a node seems like a better solution
              in my eyes.
                FastVector @Subpath
                @Subpath
                Made a video of how the pen tool is working for me.
                The first part i'm just working with the pen tool without any keys.
                The second part I'm using the control key. It's for me not totally working the same as the node tool. By double clicking on a node I don't get a new node in the middle but it will go to the object isolation mode. And to delete a node I've to go to the context bar.
                  Subpath @FastVector
                  @FastVector
                  i think i see it, adding a Node doesnt work when you
                  activate the Node Tool with the Control Key.
                  Your are right its the same here.
                  Seems if you activate the Node Tool with the Control Key
                  that the Node Tool its a bit limited then.
                  Adding a Node works only by selecting the Node Tool
                  direct.
                  • DanielD Offline
                    Daniel
                    Hey been away for while. I will continue here shortly. 🙂
                    • DanielD Offline
                      Daniel
                      Feature Idea: Fix alignment for selected objects. One of the most common steps that designers do is re-establish alignment after moving objects. So I was thinking there should be a way to fix alignment and distance between objects.
                      For instance, if three Circles are selected and horizontally spaced and the distance between set to "100 pixels," moving one of the circles should re-establish alignment and distance. It should be of course possible to toggle off distance fix. Distance fixing is not a new idea. It already exists under the name of auto layouts in tools like Lunacy: https://blog.icons8.com/wp-content/uploads/2023/07/2-autolayout-settings.mp4
                      But fixing alignments would be truly useful. It should also be possible to fix more than kind of alignment. For instance, horizontally spaced and aligned. In fact, if done correctly, it can work for entire groups of objects. We can call it aligned groups/alignment groups.
                      Think of it like this: In the image below, you can fix make each line of objects, it's own alignment group. For instance, the red circles can be fixed for alignment across the centres and spaced vertically. And the first row of circles of different colours can fixed for alignment to the top edges and spaced horizontally. Now, moving any one object will keep the matrix structure intact. This is presently not possible in any apps.
                      Importantly, it should be dynamic. Meaning, if I move the object, the others should move appropriately. https://imgbox.com/JJMryYn6 - I mean like this. But it does not fully capture what I mean. I should be able to move individual objects while retaining alignment across the whole group.
                        VectorStyler @Daniel
                        @Daniel I added this to the backlog. It would be something like the auto layout from those apps.
                        • DanielD Offline
                          Daniel
                          Pigment Blend Gradient and L*, a*, b* colour gradients. Affinity now has a pigment blend option for gradient which allows you to simulate real pigment blending between colours. Although this might seem revolutionary, it has existed for at least a decade in PhotoLine through LAB colour gradients.
                          Affinity's pigment blending
                          PhotoLine's LAB Gradient:
                          If I had to choose between the two, I'd choose LAB Gradient. Here's why. It is much more predictable in terms of resulting colour, and closer to how eye perceives real world colours. LAB includes 100% of the colours that the human eye can perceive, but arguably printers cannot reproduce. Screens can, depending on the colour gamut. It is so much more vivid.
                          On the other hand, pigment blend is a really good idea. It simulates how colours actually mix. Blue and yellow produce green, rather than dirty brown. But this introduces a third colour into the mix. It is useful in artform scenarios definitely.
                          Incidentally, and weirdly, Mesh Gradients cannot do pigment blending. A real and unnecessary oversight! It would have been quite useful to include pigment blending in Meshes as Meshes are more likely to simulate real light reflections. Oh well. Fragmentation is the biggest curse of Affinity.
                          Ideally, we would have both. But I lean towards LAB. Community can vote.
                          Edit:
                          Here's the very real limitation of pigment blending: One of it has pigment blending on. But can you guess purely by looking at the image? You can't. The answer is: The one on the left has pigment blending ON. But it's negligible. But further below is a LAB gradient:
                          See the difference?
                          Also, PhotoLine is remarkably the only tool in existence today which allows you to set a colour from different colour spaces for each stop within the same gradient. You might think, ah so what? But when you're trying to simulate real world colours, this is not a small achievement. You can mix RGB, HIS, LAB, CMYK, and Tints of colours within the same gradient. This is a remarkable thing.
                          • DanielD Offline
                            Daniel
                            They stole it from Xara, and you can steal it from them. Clicking those + signs adds new artboards on any side. It's quite nice. Xara has the same for individual objects within the artboard. Very rapidly allowing you to grid objects. As previously illustrated with the auto-layout options (see the gif in the comment on Alignment Fixing), Xara allows you to manage the space between these objects.
                            • DanielD Offline
                              Daniel
                              https://docs.astutegraphics.com/vectorscribe/vectorscribe-plugin-overview - This is one of my favourite plugins for Irritator. It is what Irritator should have aspired to be. There's so much here you can take. Planting it here, will come back and explain more.
                                @Daniel Some of these things are also present in VectorStyler already
                                • DanielD Offline
                                  Daniel
                                  https://vectorink.io/app/canvas.php - A software to be aware of... Look at their very clever copy function.
                                  • DanielD Offline
                                    Daniel
                                    Important quality of life improvements for UX in 1.3.
                                    1.3 is seriously impressive. Especially impressive for a product that is still just V1!
                                    Here are some very important QoL improvements necessary to make it usable further:
                                    1. Scrubbing: This is sin qua non if you want to make VS stylus-friendly. Merely pushing the pen down and dragging should allow the user to change parameters. Sliders are only useful when the user needs fine control. In most cases, such fine controls can come during the tweaking stage. When the user is designing, scrubbing allows total immersion into the work.
                                    2. Scrolling: Scrolling through fields should take the user up and down any list. Again, this makes for a very immersive user experience. Clicking and selecting disrupts flow.
                                    3. Increasing parameters factors of 5, 10 and 50. Ctrl Scroll through parameters should increase it by multiples of 5. Ctrl + Shift + Scroll by multiples of 10. Alt Scrolling by multiples of 50 - where this is possible.
                                    4. To and fro panel interaction: Imagine you have the symbols panel open for instance. Instead of going through clicks, you drag and drop the object into the panel. Boom! Done! So all styles and presets panels could work this way, making for a highly interactive workflow.
                                      Boldline @Daniel
                                      @Daniel said in XLS for features and ideas - Megathread:
                                      I went to check it out but did not see anything out of the ordinary with the copy function. No doubt I am the weak link here in understanding what was clever; would you be willing to elaborate on it when you can?
                                        I will try to implement these, but some assistance needed:
                                        This would require the use of a modifier key. And I need to know what is the parameter to be changed (stroke width?)
                                        1. Scrolling: Scrolling through fields should take the user up and down any list. Again, this makes for a very immersive user experience. Clicking and selecting disrupts flow.
                                        Example plesae
                                        1. Increasing parameters factors of 5, 10 and 50. Ctrl Scroll through parameters should increase it by multiples of 5. Ctrl + Shift + Scroll by multiples of 10. Alt Scrolling by multiples of 50 - where this is possible.
                                        Is this in number fields?
                                        1. To and fro panel interaction: Imagine you have the symbols panel open for instance. Instead of going through clicks, you drag and drop the object into the panel. Boom! Done! So all styles and presets panels could work this way, making for a highly interactive workflow.
                                        A bit difficult, but can be done.
                                        • DanielD Offline
                                          Daniel @Boldline
                                          @Boldline: Yeah sure. Did you see the copy tool? There is a dedicated copy tool. The copy tool quickly creates rotated copies of a selected object around the rotocentre. What's clever about is that you move the rotocentre and flare out the copies. That's the tool icon. I really like the interactivity of it. I can think of several ways to improve it.
                                          Now you have the mirror tool correct?
                                          But that's not really the only possible transformation possible is it? Most design software cover just 4 major transformations.
                                          1. Rotation
                                          2. Mirroring
                                          3. Shearing/Skewing/Warping
                                          4. Scaling
                                          But there are 2 more important transformations, which are not covered.
                                          1. Translation
                                          2. Glide reflection
                                          A complete transformation tool would do all of it. And this copy tool is actually a good prototype of how it could work.
                                          In fact, every single of the 17 possible wallpaper group - that's every repeating pattern conceivable on a 2D plane - can be generated by just with 4 transformations. Translation, Mirroring, Rotation, Glide Mirroring.
                                            Boldline @Daniel
                                            ok yes I had seen that but I was thinking more about the literal "copy" paste basic function tool at the bottom - i see what you mean now. there is certainly some interesting and fun abilities that can be implemented quickly with the copy tool you highlighted. I could see it as an extension of the repeater tool
