    Copy-Paste between applications - maintain object size
    4 Posts 2 Posters 2.3k Views 2 Watching
    • E Offline
      EricP
      I'm trying to copy paste shapes between VS and AD and could not find a way to preserve object size. Is there a setting I need to apply for size to be preserved ?
      VS
      AD
        VectorStyler @EricP
        @EricP Did you try the copy / paste with PDF?
        • E Offline
          EricP
          yes I did, but position is no longer honored when copying layers separately (all individually aligned to the top left corner) and group structure is lost.
          I think the issue is more on the AD side as the copied svg string has the right dimensions, but they change once pasted in AD
          <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
          <!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
          <svg width="842" height="596" viewBox="0 0 842 596" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xml:name="Untitled-2">
          <defs/>
          <g transform="matrix(1.0 0.0 -0.0 -1.0 0.0 595.276) ">
          <path d="M0.0 0.0 L0.0 595.276 841.89 595.276 841.89 0.0 0.0 0.0 Z" fill="#C7C8CA" fill-rule="evenodd" id="Untitled-2"/>
          </g>
          </svg>
            VectorStyler @EricP
            @EricP I opened a bug on this. Groups / layers should be copied correctly.
