    How to crop a vector design ?
    5 Posts 2 Posters 3.2k Views 2 Watching
    • E Online
      EricP
      I'm trying to crop small portions of large vector designs obtained through image trace + shape effects. The design is quite 'messy' due to the way it was obtained. I'm cropping parts of it to use it as a basis for the next iteration (I don't want to crop the original image used for tracing as I don't know the part I want to select in the end)
      I'm using Intersect Combine Path function, with a rectangle shape to crop the design. It works often, but also fails often and I cannot find why.
      I flattened all shape effects, I used the simplify path feature to remove extra nodes.
      In this video, you can see that Intersect boolean doesn't work with filled shapes, but works when fill is transparent : https://somup.com/cT11QiL1Or
      Any suggestion for cropping vector designs ?
      I'm attaching the file (compressed) : 0_1749201638156_croptest2.vstyler.zip
        VectorStyler @EricP
        @EricP There might be a bug here, I get the same issues.
          VectorStyler @EricP
          @EricP The problem occurs because there are a lot of very thin small objects in this trace result, and intersection breaks with these (this is a bug that I will try to fix).
          Was this traced in VectorStyler?
          But there is a workaround:
          • open the Magic Wand panel and expand it (with the knob in the title).
          • disable the Inside View option in the panel menu.
          • disable all, and enable the Thinness option.
          • select the magic wand tool and click on one of these thin shapes.
          • there should be over 14000 of these.
          • delete all these small shapes.
          • also: remove the stroke from all these objects
          • then intersection should work.
          I will try to improve the intersection to better handle these thin cases.
          • E Online
            EricP
            @VectorStyler thank you, that worked well. I learnt a new trick with the magic wand thinness
            Yes it was traced within VS
            could you please let us know what the thinness selection is looking for specifically ? is it a ratio between height and width of the shape ?
            Also, I often have trouble with selecting shapes within groups. I often end up ungrouping them for the sake of the selection but there may be a better way. I've tried the deep selector but it does not always work well in tandem with Magic Wand
              VectorStyler @EricP
              @EricP said in How to crop a vector design ?:
              Yes, something like this.
              Double click the group and that will isolate for selection.
