    Starry night : is there a way to achieve this with VS ?
    22 Posts 5 Posters 20.1k Views 5 Watching
    • E Online
      EricP @monsterfox
      @monsterfox oh wow, thanks ! I did not know how to use the shape picker, now I get it with your explanation.
      That kinda worked. I think I skipped the step "deleted the un-necessary paths" and the shape sample got positioned at middle distance between 2 nodes.
      How would you delete the paths without deleting the nodes ?
      (the paths on the picture are duplicate paths, the ones I used to extract the nodes are no longer visible)
        @EricP
        I am unsure if i have figured out what you want.
        Could be that I'm lost in translation.
        But to my understanding you like to place objects (circles)
        at the position of a node.
        If that's the case, then may take a look at Nodebox.
        Here's a link to a thread I posted once.
        https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
        In Nodebox, you can use points as object positions.
        You can place different numbers of points on an object's outline. Or import your
        Shape as SVG and use the Nodes at the Outline as Position Points for a Shape.
        Vector objects can be imported and exported as SVG.
        Here a Video
        • L Offline
          Li Xiao @EricP
          @EricP I have a very convenient method in VectorStyler. I will record a video for your reference when I get back to the computer in 10 days.
          • E Online
            EricP
            thank you both. What an amazing community
            @Subpath I was trying to find a VS approach. Thanks for the NodeBox suggestion.
            If you're interested, Cavalry has a built-in approach for this with Duplicator Shape point distribution
              Subpath @EricP
              @EricP
              Thank you,
              I'm also curious about the VS solution 🙂
              Thanks too for the Cavalry Tip, i know Cavalry and have the free Version installed.
              I like to experiment, so i know a bunch of Tools.
                monsterfox @EricP
                @EricP During the day, I tried disconnecting the node but found that it couldn't strip the node. So I consulted the external support "LI XIAO". Unfortunately, he was just about to go on a business trip, and we can only wait for his return.
                • L Offline
                  Li Xiao @EricP
                  @EricP In fact, I have thought of 5 methods in VectorStyler to do this. After testing, 3 of them should meet your requirements. The other two each require an improvement in an existing VectorStyler feature before they can work. I will record the 3 feasible methods for your reference.
                  BTW, a few years ago, I purchased a plugin for this feature in CorelDRAW, placing shapes on nodes and at line intersections. While VectorStyler doesn't have a one-step solution for this, there are methods to achieve it, which are relatively simple. It also allows for operations on multiple lines. However, it would be even better if a one-step function could be added in the future.
                  • L Offline
                    Li Xiao @EricP
                    @EricP The first method involves disconnecting all nodes, adding circular arrowheads to all disconnected lines, filling them with gradient colors, expanding them, selecting circles, deleting all unnecessary objects, creating the desired shape as a style or preset, selecting all circles, and then replacing them with the new shape.
                    @VectorStyler There seems to be a slight issue with the magic wand selection.
                    Video:
                    https://youtu.be/oGK3m270gQc
                    File:
                    0_1749103727365_shapes on path nodes.vstyler
                    VectorStylerV 2 Replies Last reply Reply Quote 3
                      VectorStyler @Li Xiao
                      @Li-Xiao said in Starry night : is there a way to achieve this with VS ?:
                      I will try to replicate this.
                      • E Online
                        EricP
                        oh wow, thank you so much. I am trying to replicate and am learning so much on the way :
                        • I didn't know we could expand the magic wand panel for additional parameters,
                        • the arrow trick (was hoping I could stop at this stage but apparently we can't control arrow size independently of stroke size)
                        • applying gradient with transparent stops and then expanding outline (very smart)
                        • using style to replace shape
                        thank you, I keep on learning
                        On your magic wand comment, it looks like your selection is constrained to inside view only. That may be the reason you cannot select all similar shapes with one click when zoomed in (if that's the issue you were having)0_1749107441200_SCR-20250605-inbt.png
                        • L Offline
                          Li Xiao @EricP
                          @EricP The second method involves similar pre and post operations as the first method, but with different mid-process steps. Due to the insufficient accuracy of Image Trace, it may cause deviations in the positions of circles and nodes. This method is not highly recommended, but simply presented as an alternative approach.
                          Video:
                          https://youtu.be/4tY2E8RZ0k4
                          File:
                          0_1749107666037_shapes on path nodes 2.vstyler
                          • L Offline
                            Li Xiao @EricP
                            @EricP The third method is the fastest, and the accuracy is acceptable (curve lengths can be set to 0.00000000001).
                            Video:
                            https://youtu.be/je_uJLwpEKY
                            File:
                            0_1749109208018_shapes on path nodes 3.vstyler
                            E S 2 Replies Last reply Reply Quote 3
                            • E Online
                              EricP @Li Xiao
                              @Li-Xiao very very creative !! thank you
                              I learned many tricks with this one, especially on separating the shapes after tracing so their center would be redefined, using Union, then break apart (ctrl K). Very very useful
                              • E Online
                                EricP @Li Xiao
                                @Li-Xiao yes, the last method is clearly the best for the original use case. Thank you so much for the effort and creativity putting all these methods in practice. I learned a lot
                                  Subpath @Li Xiao
                                  @Li-Xiao
                                  Thank you for the demonstrations too. 👍
                                  I learned many things too I wouldn't have thought of.
                                  It's always interesting to see how others solve a problem.
                                  • L Offline
                                    Li Xiao @EricP
                                    @EricP @Subpath My pleasure. The different feature combinations in VS are pleasantly surprising.
                                      Yes, it was the inside view settings.
                                        monsterfox @Li Xiao
                                        @Li-Xiao 这个操作真的很新奇,好像管理员都没有想到。这个功能我是基本用不上了。工作中没有太适合的场景。现在依然觉得论坛里你玩VS最溜。
