    Polygonal Spiral needs to add rotate parameters
    16 Posts 2 Posters 12.8k Views 2 Watching
    • L Offline
      Li Xiao @VectorStyler
      @VectorStyler Thanks.
      There are also patterns like the one shown in the image, but I have been unable to replicate it.
      https://youtu.be/YxCk-tuHAQU
      • L Offline
        @VectorStyler Rotation is now functional, thank you very much. 😍 😍 😍
        Looking forward to waveform rotation.
          VectorStyler @Li Xiao
          @Li-Xiao said in Polygonal Spiral needs to add rotate parameters:
          Do you have some examples for this?
          L 3 Replies Last reply Reply Quote 0
          • L Offline
            examples 0_1713254884258_Polygonal Spiral.pdf
            It seems like there is a missing option when creating a spiral star shape
            0_1713254910259_spiral star.pdf
            • L Offline
              @VectorStyler Thank you very, very much. it's even more impressive than I imagined.
              • L Offline
                @VectorStyler During use, it was also found that two options were missing:
                1. The corner radius values for polygon spirals lack customization for inside and outside separately;
                  https://youtu.be/hVoS3urnqLY
                2. Spiral and polygon spiral need to support custom shapes.
                  2_1747470231187_custom 3.jpg 1_1747470231186_custom 2.jpg 0_1747470231185_custom 1.jpg
                  it is not clear how this would work for spiral?
                  • L Offline
                    @VectorStyler If Polygonal Spiral can create elliptical spirals, there is no need to modify Spiral. This feature is commonly used in laser engraving, and there are plugins in CorelDraw that offer this function, but I dislike the subscription model.
                      Send me a link to this.
                      • L Offline
                        @VectorStyler Offset can solve some problems, but decay doesn't work.
                        0_1747481370578_Offset.vstyler
                          However, the Polygonal Spiral is missing a rotational parameter, and I hope it can be added.
                          There is a Rotation parameter for the polygonal spiral that can be found in the Shape panel.
                          • L Offline
                            @VectorStyler I know, this feature was added in version 1.2.020. Thanks again.
                              @Li-Xiao My mistake, I read the original post and did not check the date.
                              The actual answer should be about the spiraling case: this will require a new shape type. I will try to add this to version 1.3.
                              • L Offline
                                @VectorStyler Looking forward to the upcoming 1.3 version, thank you very much!
