    • DanielD Offline
      Daniel @VectorStyler
      @VectorStyler: This need not be a separate tool. It is an act of transformation, therefore logically related to normal transform tool. 🙂
      • DanielD Offline
        Daniel
        @VectorStyler: Ctrl + Shift + Scroll over fill to change hue, with on-canvas label to show HSL values. The same scrolling over stroke changes stroke width.
        • DanielD Offline
          Daniel
          <<>> keys to proportionally resize objects by set percentages.
          • DanielD Offline
            Daniel
            @VectorStyler: Transient zoom: Hold down a key for a set zoom percentage at mouse cursor location for as long as the key is held down. One implementation: Inkscape.
            • DanielD Offline
              Daniel
              I went over all my previous suggestions and realised that a great number of them centred around improvements to the pen tool. So I am going to summarise them all in this thread for simplicity:
              1. Additional pen modes: Bezigon Model, Catmull Rom Spline and Arc Spline - See XDP (for CR), Gravit & FH (for Bezigon) and Boxy SVG (for Arc Spline)
              2. Interactive feedback for nodes and paths: See Lunacy & Boxy SVG
              3. Tab to next node with auto panning if node out of view: See XDP
              4. Merge Node Editing & Curve Creation: See GIMP
              5. Vector Networks: See VGC.io and Figma
              6. Lock Nodes: See PL
              7. Group Nodes: This is completely new.
              8. Implement Tangential Node: See FreeHand
              9. Allow 15-degree guides and snap to curve edges: See Graphite.Rs
              10. Allow subpaths: See Affinity & PL
              I invite other users to vote on what they think ought to be the order in which these improvements and ideas for pen tool should be. For me, right at the very top of the pile goes Bezigon and merging of node editing and curve creation capabilities. And Bezigon would require Tangential nodes and 15-degree guide to be meaningful. This would be followed by Lock and Group nodes.
                VectorStyler @Daniel
                Some of these will be separate tools. In terms of clicks it is better, and then you can assign shortcuts to those tools.
                1. Interactive feedback for nodes and paths: See Lunacy & Boxy SVG
                I have to learn more about this.
                1. Tab to next node with auto panning if node out of view: See XDP
                Yes.
                1. Merge Node Editing & Curve Creation: See GIMP
                Problematic. Both tools are already overload the existing modifier keys. But it is possible to switch temporarily.
                1. Vector Networks: See VGC.io and Figma
                Yes, but later.
                1. Lock Nodes: See PL
                Possibly yes.
                1. Group Nodes: This is completely new.
                Same as above.
                1. Implement Tangential Node: See FreeHand
                I have to learn more about these. Any examples?
                1. Allow 15-degree guides and snap to curve edges: See Graphite.Rs
                Not sure, but both of these might exist. Guidelines can be rotated to any angle, and then there is Collision snapping mode.
                1. Allow subpaths: See Affinity & PL
                I think these are supported. Just use the Combine path operator.
                • DanielD Offline
                  That's fair. Works for me.
                  This is a quality of life improvement. This can wait.
                  Perhaps, there's a misunderstanding here. I'm not suggesting that we getting rid of the node tool. The node tool should exist on it's own. But the pen tool should be able to manipulate both nodes, handles, add, delete nodes, and so on. I will record a video to demo this clearly. Once you see it, you can assess if it's possible. This circumvents the need to use modifier. It is highly intuitive and useful. Combined with other modes previously suggested, it would be supremely meaningful.
                  I will record video for this.
                  Will need to check this further to see if it works as it should.
                  It's not about combining path. It's about continuing to draw separate curves as a part of a single path. Is that how it works?
                  VectorStylerV L 2 Replies Last reply Reply Quote 0
                    No. Is this about continuing to add curves to a single path? Show me some examples.
                    • DanielD Offline
                      @VectorStyler: Yes. I can discontinue a curve. Click somewhere else, and it would be considered a single path. I will record video later this weekend.
                      • L Offline
                        lilith @Daniel
                        @Daniel said in XLS for features and ideas - Megathread:
                        ''But the pen tool should be able to manipulate both nodes, handles, add, delete nodes, and so on.''
                        Are you talking about Affinity Designer‘s pen tool
                        • DanielD Offline
                          Daniel @lilith
                          @lilith no. Xara and gimp.
                            FastVector
                            When using the pen tool now: you can add nodes by clicking on the path, and add handles by click and drag on the nodes. When using the control key you can use a lot of the functions of the node tool.
                            What I would like to see is that the deleting of nodes would work the same way as in the node tool.
                            Windows 10 | 1920x1080 | 125%
                            • DanielD Offline
                              Daniel @FastVector
                              @FastVector: yeah, my case is for removing the modifier. Why do we need it? Try Gimp once and see for yourself. It makes perfect sense to do the entire operation without any modifier whatsoever.
                              The precedent for this was set by the ill conceived illustrator pen tool which splits two logically related, sequentially performed operation, creating curves and manipulating nodes.
                              I'm recommending that we get rid of it the unnecessary modifier key.
                              Double clicking adds a node.
                              Middle clicking the node removes nodes. Simple. Clear. Economic.
                                Boldline @Daniel
                                Currently, clicking directly on an existing node adds a new node in the exact center of the path - this is a tool I'd not want to lose, though I could see adding a modifier to it since it's less commonly used than erasing a node
                                S F 2 Replies Last reply Reply Quote 2
                                  Subpath @Boldline
                                  ... clicking directly on an existing node adds a new node in the exact center of the path ...
                                  press the plus key "+" once does exact the same
                                    FastVector @Boldline
                                    @Boldline For me this is only working when I'm using the node tool and then I've to double click on a existing node. (I quess something different in my settings for the pen tool)
                                      VectorStyler @FastVector
                                      @FastVector said in XLS for features and ideas - Megathread:
                                      Could be a settings issue. Send me your workspace/settings files (Help -> Reveal Workspace).
                                        Subpath @FastVector
                                        @FastVector
                                        Made a little Video here
                                        Using Ctrl+a while the Node Tool is selected
                                        will select all Nodes of a Shape.
                                        • DanielD Offline
                                          Daniel
                                          How about single clicking curve to add a node. Double clicking a node to delete the node?
                                            Subpath @Daniel
                                            @Daniel
                                            A single click to add a node seems too risky to me, since its
                                            used to select a section of a path, and it's easy to click accidentally.
                                            And double-clicking a path to delete a node?
                                            I'm not really convinced.
                                            A modifier key to delete a node seems like a better solution
                                            in my eyes.
