    Allow for more immediate custom color choice in colorize panel?
    2 Posts 2 Posters 2.1k Views 1 Watching
      If I wanted to choose certain specific colors from a source palette, but not use the entire palette to let VS pick from, would it make sense to add that option to the colorize panel?
      It seems I would need to create a new palette with only the specific colors I wanted and then load that in and select it to get that to work in the colorize panel.
      I was envisioning an option where I could select multiple colors quickly from the mode chosen, such as a palette I use.
      0_1738558082971_e1e284d8-79c3-4584-b749-676f7fc60e02-BLD 2025-02-02 at 23.47.07.png
      Or is the feature I'm envisioning found in another section of the "Replace Colors" menu? For example the "replace colors>replace color submenu panel?
      0_1738558338772_4002729a-1f81-4a71-aa13-b980f49104c8-BLD 2025-02-02 at 23.52.10.png
        @Boldline I will try to add this to the colorizer as it would be a much simpler solution than the replace color.
