Altered pivot point doesn't apply
 How can I control scaling according the altered pivot point? It doesn’t work on mouse-drag-scaling.
 This issue also occurs with tilting. It would be perfect if this problem could be resolved.@VectorStyler
 @Raaskot When scaling with the transform tool, the pivot is automatic (opposite corner) Use the scale tool fro scaling arou  nd the pivot: nd the pivot:
 Cool! That's what I needed.Short key for rot. tool is already given shift-r, I see.
 I've added new short key shift-s for the scale tool and now it works fine.
 @VectorStyler  Can we add a fixed pivot point function at the position indicated by the red arrow above? This will make the operation more convenient, and users can also choose whether they need a fixed point. Although choosing a zoom tool can fix the pivot point, it is always not as convenient to operate, Can we add a fixed pivot point function at the position indicated by the red arrow above? This will make the operation more convenient, and users can also choose whether they need a fixed point. Although choosing a zoom tool can fix the pivot point, it is always not as convenient to operate,
 @monsterfox said in Altered pivot point doesn't apply: Can we add a fixed pivot point function at the position indicated by the red arrow above? Does this mean an option to use the pivot for scaling?
 @VectorStyler  That's what it means. Actually, I think these functions can basically disappear. There are repeated occurrences. That's what it means. Actually, I think these functions can basically disappear. There are repeated occurrences.
 Very nice upgrade v. 1.2.057
 Now transforming with Transform tool (V) works fine.
