If I delete a palette color, does it only delete from that specific panel?
If I delete a color from a palette, I get the popup below:
Does this mean it's being deleted only from the "test" palette in my example? What does it mean by "external color palette file"? One guess I had was that it would also remove it from the original source palette I opened and had moved a copy of that color from -
@Boldline said in If I delete a palette color, does it only delete from that specific panel?:
The palette is not stored in the document, but in some other file.
And the color will be deleted from that file also (cannot be undone). -
@VectorStyler ok so to clarify this - VS is essentially warning me that deleting the color from the palette is a permanent change to that specific color palette.
Yes
